Car Toe Problems
Old Aug 11, 2012 | 11:18 AM
joffy's Avatar
joffy
SLOW LEARNER
Default Car Toe Problems
Not only have i broken my toe, my 3dr is toeing out badly. it should be going for its first MOT on wednesday since being rebuilt but the wheels are visibly toeing out. I have adjusted the rod ends in as far as they go and i still can even get them straight. I have the pinch bolt (2wd) hubs and TCAs on it, would this make a difference? We have measured everything up against my dads saph and we cant see a difference anywhere, anyone got any ideas??
Any help would be mega
Old Aug 11, 2012 | 05:34 PM
stevieturbo's Avatar
stevieturbo
C**t
It's a longshot....but how about taking it to a garage with proper wheel alignment equipment ?
Old Aug 11, 2012 | 10:23 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
grind the rod ends back a little, that'll sort the limiting problem out, sounds like the issues is with the 2wd parts to me.
Old Aug 12, 2012 | 08:31 PM
joffy's Avatar
joffy
SLOW LEARNER
Taking it to a proper place aint much help unless they can adjust it straight and grinding the rod ends down will mean taking nearly an inch off them which im not sure will still be safe,
apart from the pinch bolt/castlated nut fixing, is there any difference in dimensions of the TCAs between 2wd and 3dr? Especially between the hub and ARB fixings?
Old Aug 14, 2012 | 12:55 PM
joffy's Avatar
joffy
SLOW LEARNER
Anyone got any ideas??
Old Aug 16, 2012 | 09:57 PM
cossytel's Avatar
cossytel
assuming you have x member & rack form a rwd car it should work unless the rack has the longer 4wd tie rods fitted
I think from memory they are about an inch longer
Old Aug 17, 2012 | 08:23 AM
Marc sierra's Avatar
Marc sierra
I think it should be a problem with the rod ends being too long. Perhaps you have Granada mk3 rod ends on it, those are longer than Sierra ones too, but will fit both the rack and the hubs.
Old Aug 17, 2012 | 08:30 AM
joffy's Avatar
joffy
SLOW LEARNER
We checked the rod ends and the rack 'drumsticks' and they are exactly the same as my dads saph. I now have a set of adjustable TCAs so will try them at the weekend and see if that helps,
Old Aug 17, 2012 | 08:50 AM
Marc sierra
Any pics of the TCA, hub and rod end? Perhaps that might show the problem?
Old Aug 17, 2012 | 01:49 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
what pinch bolts are you using
Old Aug 17, 2012 | 02:02 PM
joffy's Avatar
joffy
SLOW LEARNER
er, the bolts are ford ones for a 2wd cos i think? would they make a difference?
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Davemurphy007
Motorcycle Chat & Sales
Aug 14, 2015 05:58 PM
