s14a 200sx problem..
My mate has a 200sx s14a, today i've fitted fmic hks blow-off valve and all associated pipework, it sounds awesome, however, when flooring the accelerator it seems to hold back almost like it's cutting the power?
the blow off valve vacuuum pipes goes accross to the standard boost controller thingy, is that right? - the other pipe goes to the wastegate actuator and the other to the intake pipe. i'm sure this is correct but dont really know?
Car is standard low miles except, exhaust, filter, uprated fuel pump and decat. we've tried new plugs as not sure if the boost was blowing out the spark? runs fine when stationary and revs cleanly.
any ideas?
any ideas?
neeeeeeeeooowmmmm
As it's got an uprated fuel pump, my money's on boost leak. They're so common on these with standard intercoolers/pipework!
What plugs is he running? And what gap?
Edit-I think the vacuum pipe on the BOV is supposed to go the the inlet manifold, that's where it is standard on these.
Right see somone has been there before and the standard re-circ valve has been removed with a bolt wedged in the end of the pipe. This pipe goes back to the inlet, so maybe this needs to go to the bov?
If so where does the pipe go from the boost controller thingy? On the old pipework it went onto a boost pipe but there is no connection on the new pipework. Can I join this onto the inlet aswell do does it need to be before the throttle or does it not matter?
I know a kit a friend fitted years ago was the same, it had no takeoff for the boost control, which is a bit stupid really.
Cheers for the help lads, told him to get a take off from ebay that goes into the silicone hose but think I'll weld it into the pipe from the turbo-intercooler as there's kinda where it was before. And we I'll put the bof pipe to the inlet.
So yeah thanks for the help chaps!
BlueSmoke
18-10-2005 10:22 AM
