Cosworth smoking
Cosworth smoking
Hi everyone,
Why is my cosworth smoking?
It has always smoked a bit but I have just rebuilt it and if anything it seems worse!
Just built a new engine after cracking a bore...
New gaskets
New turbo
New valve stem oil seals
new bearings
Running the pistons that come with the block - was told it only done around 10k since a rebuild including pistons and rings (looked pretty new)
Now from reading older posts most people say
Turbo
Stem seals
Rings
Breather system
I did check that breather system whilst I had the engine out and was good. However I don't know if it's good enough?
Running stage 4 (greys, t38)
Do I need a catch tank type breather? I just have the little pot type that mounts on the bulk head!
I only notice the smoke when I come to a stand still after being on boost.
It doesn't smoke on start up or idle
Any help would be much appreciated
Danny
New gaskets
New turbo
new bearings
Turbo
Stem seals
Rings
Breather system
Danny
Competition Technology
probably not the case though, is it running high boost ?
i run 10w - 60 fully synthetic in the escort, no smoke at all, only the grey smoke on idle in the morning until its warmed up, dont know what to suggest other than head gasket being pushed away from the block on high boost, letting coolant into the bores, then when off boost it closes the gap and idles normally?
Had block decked + head skimmed and now using WRC head gasket
