compression ratio help please as im stuck :(
trying to calculate my ratio but it confuses the hell out of me
my engine is a 94 2.0 silvertop
crank stroke is 88mm
piston dish -9
bore size 85mm
head chamber led to beleive is 48cc
st170 head gasket squashes to 0.9mm
eagle rods with larger diameter gudgeon pin
if there is anything else needed please post many thanks guys
piston dish -9
bore size 85mm
![](https://passionford.com/forum/images/smilies/roi.gif)
this is the link for the pistons i can find which state my pistons are the top ones part numbers on the boxes for them,
http://www.nolimitmotorsport.com/supertech/pistons.html
is this accounting the valve cutouts in the pistons
im presuming my pistons are the top ones as there is no part numbers on the boxes for them,
Those pistons list a cr of 8.7:1 with a 48cc head volume.
I'd assume the -9cc 'dish' value would incorporate those. The only way to ever 100% know is too measure everything with bore gauges, DTIs, cc fluid and complex maths. Then you'll know each individual cylinder to three decimal places. But you cant.
![smiley_abuv.gif](https://passionford.com/forum/images/smilies/smiley_abuv.gif)
it certainly sounds pretty good for a zetec turbo,i had tried using google and just head pickled myself lol,
i tried the link earlier marty posted and either i got it wrong as it came back as 3.3 lol
firstly can i say THANK YOU for taking the time to help with this![smiley_abuv.gif](https://passionford.com/forum/images/smilies/smiley_abuv.gif)
Best thing to do to comp check it once built. Then you'll know
No worries chap, guessed the ZT might be destined for your S1. Was known on S1T a few years back, recognised the name. It is a confusing thing. I do it day in day out at work so I kinda got it down these days lol.
Best thing to do to comp check it once built. Then you'll know![Top](https://passionford.com/forum/images/smilies/smile011.gif)
another query is the pistons i have got are stated for the svt ie st170 with the smaller combustion chamber so im guessing in a zetec turbo silvertop with a bigger combustion chamber will drop it down a little more
though im confused as i thought the stroke on a st170 were different
muz
30-09-2015 08:29 AM
