s2 Cuts Out After 15 secs :cry: (FAO STU or similar tek :D)
Old 03-03-2005, 06:05 PM
MK5RST
MK5RST's Avatar
Default s2 Cuts Out After 15 secs :cry: (FAO STU or similar tek :D)
It starts from cold find but after around 10 seconds is gets lumpy then totaly dies unless you rev it, ive posted a cpl of times but its been pushed down, perhaps the right people wernt on to answer? Just a quick reply is all i ask Im sick to death of this problem, cheeRS. pete
Old 03-03-2005, 06:10 PM
L33 BYT
L33 BYT's Avatar
Pete Get your self this post in the Escort Section also.
Have you had any work done on it recently?
Old 03-03-2005, 06:15 PM
MK5RST
MK5RST's Avatar
cheers lee, ive just done an MK5 conversion, Nightmare!!!, posted in RST section but not many people browse there?
Old 03-03-2005, 06:19 PM
L33 BYT
L33 BYT's Avatar
Is it kicking out loads of black smoke as well?
I would say check your wiring on the inlet manifold. The main man Stu from MSD gave me a little guidance as all my origianal connections had been chopped and I had a knightmare recorgnising them.
I ended up doing it from the colour coding from a haynes manuel and job done.
Old 03-03-2005, 06:25 PM
MK5RST
MK5RST's Avatar
Hmm, the loom came from an XR2 running well, i know the guides tell you to put the yellow and black wires to an ignition live but thats wrong, it should be a cranking live, ive tested that and it aint that problem, No, No black smoke, all connections on inlet are right? Any more suggestions, hope stu reads this (Will be going to him for a rebuild next winter cmon where r u )
Old 03-03-2005, 06:35 PM
MK5RST
MK5RST's Avatar
XR2 Running s2 gear btw!
Old 03-03-2005, 07:58 PM
MK5RST
MK5RST's Avatar
Old 03-03-2005, 08:12 PM
MK5RST
MK5RST's Avatar
WOOOOO, Just been reading another post about unmetered air, my breather is broken, the cap that goes on the rocker breather (The 1 with vacume pipe) Is broken off, would this cause my problem? CheeRS. Pete
boeb
09-01-2020 05:11 AM
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: s2 Cuts Out After 15 secs :cry: (FAO STU or similar tek :D)
