Polybushing your car
Old Jul 5, 2012 | 08:39 PM
adampotten's Avatar
adampotten
1.3 POPULAR
Default Polybushing your car
As above what advantages are there? and more importantly what do they actually do ?
Thanks
Old Jul 5, 2012 | 08:41 PM
Mark_'s Avatar
Mark_
They dont perish like rubber bushes, They also stiffen up the car which improves handling,
However some Polybushes are to 'firm' for road use and will vibrate through the car.
Old Jul 5, 2012 | 08:49 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
As above really. They can totally transform a cars handling, or ruin it for road use. You can get ones that have a similar flex to rubber, but with the benifits of MUCH longer lasting.
Old Jul 5, 2012 | 09:01 PM
mk2 cossie's Avatar
mk2 cossie
pretty much what they said above
fully polybushed my car, and the difference is quite noticeable. not harsh on bumps, no extra noises or vibrations (maybe a tad more diff whine now ), annd stiffened the ride up quite nicely too
Old Jul 6, 2012 | 12:27 PM
smudger068's Avatar
smudger068
As above tbh,
I have done this on my focus mk1 and was better than when it first got it.
but remeber to take into consider the cost of having the geometry setup again, will be more expensive depending on suspension adjustability
id recommend it anyday if you have the money
Old Jul 6, 2012 | 09:20 PM
Have you replaced the rear bushes in the back arms.
Old Jul 6, 2012 | 10:03 PM
Rsmat's Avatar
Rsmat
Glenn mine are coming out mate and I'm going for GGR ones as I can feel a ever so slight twitch on cornering.
Old Jul 6, 2012 | 10:12 PM
darrenb16two's Avatar
darrenb16two
Made a huge difference on my s2! One of the best mods I've done
Old Jul 6, 2012 | 10:53 PM
mk2 cossie's Avatar
mk2 cossie
yup, replaced the standard rubber stuff quite nicely
if only the standard stuff came out as well as the Superflex bushes went in
Old Jul 7, 2012 | 04:39 AM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
i always fount that they give extra confidence in the corners, defo a better turn in thats for sure. well worth doing on any motor even more so on these old classics
Old Jul 7, 2012 | 04:48 AM
whizzisat114's Avatar
whizzisat114
You get a much improved positive feel through the car as the suspension mountings dont move around with hard braking / acceleration
One step down from rose joints but a big improvement over rubber bushes
great for fast road
Old Jul 7, 2012 | 10:24 AM
The slight twitch is your car coming on boost Matt lol.
Old Jul 7, 2012 | 10:27 AM
Were the old bushes a nightmare to get out.
Does you car handle ok with the bushes fitted to the rear arms.
Ive heard some people say there ok with the poly bushes and they couldnt tell the difference between polys and standard.
Then some people say fit the standard bushes.
Old Jul 7, 2012 | 10:45 AM
Ade500's Avatar
Ade500
Fixing Fords
Agreed
Old Jul 7, 2012 | 11:54 AM
mk2 cossie's Avatar
mk2 cossie
no problem with mine at all, but then the mk2 granada only had rubber bushes as standard anyway. the mk3 cosworth and the xr/rs sierras had a type of spherical bearing bush i think
Old Jul 9, 2012 | 08:36 PM
adampotten's Avatar
adampotten
1.3 POPULAR
so its worth doing then by the sounds of it. I have a set for my escort was wondering if it was worth doing them cheers guys
JoeyBoyden
Jan 4, 2024 02:36 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Bailes1992
Aug 16, 2015 07:14 PM
