VW PD TDi sump change?
Anyone done one, just servicing dad's golf for him and the sump plug pulled the thread out with it on the way out!! bastard aluminum sumps.
How do you get to the 2 sump bolts on the box side that are hidden? surely not a box off job?!
Hi mate ive removed loads of these over the years they are fairly easy to get off there are 2 or 3 bolts through the gearbox bell housing which are a bit fiddly you will need a long ball ended allen key socket for those. Alternatively we used to get them helicoiled when i worked at audi no sump removal required.Hope this helps
big floppy donkey dick
i use a T bar allen key with pair of grips to mole grips clamped on crack them off.
use the white VW sealer to put it back together, nothing else
absolute doddle to do, 20 mins maby?!
SMILER258
28-09-2015 09:04 AM
Mr S1
20
27-09-2015 04:06 PM
