Boost problem
Old Jun 28, 2012 | 05:45 PM
waynefrst235's Avatar
waynefrst235
Default Boost problem
Hi folks. Posting on behalf of a mate. Fitted a replacement engine into his Saph but it is making zero boost. Stage 3 spec on a t34.48. We have tried the following:
3 different good turbos.....the t34.48, a t38 and a standard t3
2 amal valves and running it without
3 different MAP sensors, 2 are brand new
Blanking dump valve off
Plugged in L8 and L6 Ecus
The car has a brand new loom so in theory the wiring side should be fine
All boost hoses are new and tight
The engine runs fine, just makes zero boost. Piped a boost gauge in and it goes to -0.8 at idle and 0 under load
Any help or ideas would be appreciated
Cheers, Wayne
Old Jun 28, 2012 | 06:33 PM
the_frozen_one's Avatar
the_frozen_one
Cheers, Wayne
Did all 3 turbos have there own wastegates and actuators? Also is there a bleed valve in the system?
Old Jun 28, 2012 | 07:47 PM
waynefrst235
Yes they all had wastegates and actuators, didn't matter which was used, still no change
There isn't a bleed valve as far as I know
Old Jun 28, 2012 | 07:51 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
sounds like something significant, leaking boost pipe perhaps?
Old Jun 28, 2012 | 07:54 PM
waynefrst235
It does seem to be like when a boost pipe is off, just doesn't build up pressure but all pipes and hoses are new
The intercooler appears to be ok, it's a fairly new one too
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
