help!!! blue injectors!!!
300bhp yes please!
Wicked i hav a fiesta rs turbo and its running 15 psi on blue injectors and a superchip every1 i speak to says it ain't possible so i'm thinking i might hav cosworth blues ?????
300bhp yes please!
The person i brought my rs off was running 180bhp @ 10psi and has done sum cossie bit for sum reason cossie amal valve i think he might of found a way lol
300bhp yes please!
Yer mate i know i'm running 15psi now and done a absolute shit load now i'm goin to change me fueling and go the whole way thanks for you help
As a few people have suggested cossie injectors will not work on fiesta management unless you are a clever cookie and alter the impedance using resistors. Don't quote me on the using resistors as I am not too clued up with electronics but the impedance will have to be changed somehow because they are of totallly different values. A fiesta uses high impedance 16 ohm and cossies are 5 or 6
Turn the boost down asap as you are on borrowed time and the injectors will be working their tits off. Pretty sure you shouldn't run them over 80% duty cycle.
What Fuel pump are you using?
Good Advice,
300bhp yes please!
as far as i know standard i will be fitting a sytec 300bhp soon as i can and an omex management system green injectors 3 bar map sensor and a sytec pressure regulator then she will b ready for the rollers
300bhp yes please!
thanks for the advice Oranoco she is off the road at the min goin to fully underseal her put new sills in and wax oil all the inna sill and get her shell 110% safe the be sortin the fueling and management issues i hav lol thanks tho
