scratches on bodywork
Hi folks.
What is the best was to try and treat/get rid of scratches and scuffs on bodywork.
I've got a few marks on my range rover and as the car is black they show up a lot.
So, what's the best thing to do, something like colour magic or t-cut or some good quality polish. Or should i get it professionally mopped.
No ideas on this sort of thing so your opinions please.
Thanks.
Thanks.
depends on how deep they are, a polish with some cutting compound in it might be enough, or a wet sand with some fine wet and dry might be required.
Machine polished black cars look the bollox,don't forget to get it hand finished afterwards to avoid swirl marks,but any good valeter/detailer would know that.
It'll look transformed if the jobs done well.
The scratches are only superficial, so is it worth having a go
myself first.
What do you mean by 'hand finished afterwards to avoid swirl marks'
Cheers.
myself first.
Cheers.
If you want a spotless finish and a great base then check out some professional detailing/paint correction
http://www.whitedetails.co.uk/index.php?id=189
be wary though, I have seen some valeting firms and body shops that think you can just slap a mop across the car and it's all done and leave more swirls than when they started.
Fart of the Purniture
Whilst we are on the subject, someone recently said to me that I should have used polish after T-cut as I need to protect the paint after I used the T-cut?
I started with a clay bar, then t-cut then buffed it with a soft cloth
Looked great, but then the polish comment?
Can anyone recommend a good detailers in the West Yorkshire area?
Cheers.
T-cut is a cutting compound designed to cut through the paint surface, polish does the same but less aggressive, they dont add protection.
You did right, clay the car, then polish, then you need to use a wax or sealant to protect the paint.
You can then rewax every few weeks to keep it topped up, and use a quick detailing spray for after washing when you havent got the time to wax.
There may be some on here, but also check out
http://www.detailingworld.co.uk/
see who is in your area. It isnt cheap, I would guess £300 - £500 depending on what needs doing and how bad the paint is. Lot of work when done right but the results transform the car.
rsguy
44
29-09-2015 03:29 PM
