Fitting harnesses - whats best
I'm about to start fitting a set of 5 point harnesses. Having previously fitted 3 point harnesses to a different car, I used two seat belt mounts for the lap part of the harness and the rear seat belt mount for the harness part
My current car only has one seat belt mounting point for the lap belt (other part was attached to the original seat), and for the rears, I have two straps rather than the one I had before.
Hows best for me to fit them. I assume I'll need to weld a plate to the centre tunnel for the lap belt, a plate to the floor for the crotch strap, and two plates to the rear for the harness part?
Should I weld a plate for both sides of the lap part? Should I tap the plate, or use a nut? And what thickness plates should I use.
Sorry for the long winded description for whats essentially a simple job
Yeah ideally you want the plate on the outside of the panel so it's trying to pull the plate through the panel rather than pulling the weld off the panel. If you really want the plate on the inside though make one that is much bigger and use at least 3mm thick steel. As has been said already, there's a good chance the shoulder straps are intended for roll cage mounting so check that out also so it all works properly when you most need it.
muz
16-08-2015 12:57 PM
saph in dorset
14-08-2015 10:10 AM
track.focus'd
12-08-2015 05:53 PM
