wheel spacing on cars...
i have jst bought sum 50mm springs for my 2000 tddi focus and have got them fitted, i wna keep the standard wheels but bring them out with wheel spacers.
whats the limit for wheels to stick out??? or would it be a problem for the suspension?
do you guys do window decs for this forum as i go to local cruises!![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Its a difficult one mate, slightly stretched tires help an awful lot as do rolled arches to get everything to fit right. You'd need to check with an mot tester for the legalities but tbh as long as tire tread is under the arch with minimal stretch then you should be fine.
nice one, cheers for that guys!! all springs are now on, front is pretty low, but the back is higher than i was expecting so i shal get 5mm spacers and see how it goes. any idea where i can get my side bumpers sprayed??
Nevermind proper spacers. Of more importances is make sure you have sufficient length wheel bolts/studs after the spacers are fitted.
Wouldnt be the first time some muppets with spacers have had their wheels fall off.
Adam Graham
06-09-2015 06:04 AM
