Replacing Lambda Sensor
Old Apr 15, 2012 | 03:56 PM
Jasoncmor's Avatar
Jasoncmor
Default Replacing Lambda Sensor
Hi all.
Im about to change my lambda sensor on my car.
Its a fiesta mk4 1.25 with 98k on the clock.
The new lambda sensor has a round connector, but the old one is square / rectangular in shape. Can I just cut the plug off and solder the wires together, just as long as they match up with the wires on the plug socket?
Old Apr 15, 2012 | 04:27 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
That should work, but you should be able to get an adaptor lead to convert the lambda plug to the car plug. I did when I got a replacement for my DOHC Sierra.
Old Apr 15, 2012 | 04:44 PM
Jasoncmor's Avatar
Jasoncmor
Cheers for that.
I cannot seem to find anything by what you describe.
Jason
Old Apr 15, 2012 | 04:46 PM
Jasoncmor's Avatar
Jasoncmor
The lambda sensors have different tips aswell, the original one on my car has a pointy tip where as the new one has a straight tip.
Is this going to cause any problems?
Jason
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
