Compression differences for supercharging and turbocharging?
Old 02-04-2012 | 04:02 PM
mobb-black's Avatar
mobb-black
Default Compression differences for supercharging and turbocharging?
Another idiot post.
Jamsport build 300bhp engines with a supercharger using standard internals and compression. When companies achieve the same result with a turbo they need to lower the compression with new pistons.
How come? Why can't a turbo engine achieve the same power without lowering the compression given that they are both forms of forced induction?
Old 02-04-2012 | 05:04 PM
SiZT's Avatar
SiZT
Its because Jamsport use Rotrex chargers which give a linear boost plot and power graph
Old 03-04-2012 | 12:23 PM
mobb-black's Avatar
mobb-black
So because you don't get a sudden dump of boost it's not as stressful for the internals?
Old 04-04-2012 | 07:36 PM
stevieturbo's Avatar
stevieturbo
C**t
Originally Posted by mobb-black
Another idiot post.
They do ? Since when ?
Old 04-04-2012 | 08:37 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
The days of low compression Turbo engines should be gone its not required. My compression was raised from standard even when running 2.9bar.
Old 04-04-2012 | 08:46 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
engine management and better manufcturing means compression ratios can be higher than in the good old days as environments can be changed more accurately.
i run an 8.5:1 on my zetec turbo and plan to get the boost up to 2BAR as soon as i sort a clutch to hold that.
Old 04-04-2012 | 08:51 PM
SiZT's Avatar
SiZT
All depends on the engine and where the boost is made
Old 04-04-2012 | 09:05 PM
focusv8's Avatar
focusv8
Superchargers are generally used at lower boost, Jamsport quote 11psi for thiers.
I'm not a Turbo person but I rarely see people talking of Turbo boost so low, it's usually wind it up and wait for the POP.
Old 05-04-2012 | 09:08 AM
mobb-black's Avatar
mobb-black
yeah well it just made me think. If Jamsport build a turbocharged Duratec it's specced with low comp pistons. The supercharger version isn't so I just wondered how come if both conversions produce a similar base line of power lol.
I get these random questions to ask all the time n have to post on here when my dad is sick of me nagging lol.
Old 05-04-2012 | 10:32 AM
SiZT's Avatar
SiZT
Like turbo's, it all depends on engine spec. There are plenty of high boost charger conversions out there
The rotrex chargers Jamsport use are centrifugal superchargers which increases airflow (and boost) as the revs rise whereas turbo's hit there max boost as soon as they can. I suggest you read Stu's technical articles which may (?) have sections on chargers
wowk
30-03-2021 07:49 PM
01-11-2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
03-10-2015 10:44 PM
Fezman1
02-10-2015 01:22 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: Compression differences for supercharging and turbocharging?
