WRC turret extentions
For give me im doing this from my phone as i have no pc at the moment.
Well hear goes... i have modified my turrets on my sapph to fit some addjustable top mounts
now where i have cut it down i may need to raise it back up as to not loose any traval either that or make the shock shorter
dose anyone know where to get the WRC type top hats or has anyone got any input as to what i should do?
Many thanks
Many thanks
aka Turbosailorboy
Turrets have been trimmed and mig welded in place already
Yeah it's a hard decision, luckily for me the bay needs painting anyway.
But looking at the pic you've posted, those will have even less height than a normal eccentric comp brake mount due to the way the sliding adjuster bit is mounted underneath.
How hard is is to match the Racing Turd colour
Baby Cheesus
miller, if your worried about the paint, couldnt you cut the hole bigger on the oe turret and then fit the ones like richie posted from underneath and use a cap head bolt and washer on top with nuts on the underside, if you get what i mean lol. as all the weight of the car will be pushing up on them anyway.
that way you could just paint the turret extensions, without screwing the paint on the shell
Do you know what, id leave it in primer for now for all i care fpmsl... im going to kick its cunt in on track any how lol
you got any pics of them being fitted mate. i just dont like the thought of all that stress on just the welds but i guess thats what the wrc cars had any who...
hello dude.
i would not do it like that, there is not much of a lip on the wrc top hat to sit on the under side , all the weight of the cars going to be sitting on a 5mm lip,
on my escort it was painted before i new i needed theses top hats , all that we had to do was blow in the turrets , it was no big deal. if worth doeing the job its worth doeing rightget them welded on.
gordon vincent or mk motorsport will make you the top hats . they would be my choice. dewitts will have the rose joint parts .
thanks steven
my fiesta suspenion tops have the same type top hat but it will allso run with a alloy spacer ring fitted , this will let me run the car an extra inch lower with out messing the suspenion travel
thanks steven
thanks steven
that fiesta is not mine mate its a wrc rally car mc neill motor sport built here in ireland , they buit my old escort , and are now building my new jwrc fiesta to . i sold my escort shell to gatecrasher.
here is escort finished
this is only the stage my fiesta is at , its got a long way to go before its finished lol
thanks steven
the wrc ones will be no good to you though mate the diameter will be to small you will be better off getting some steel rolled to the same diameter as the turret & getting some 5mm profile rings to match the turret & bolt pattern like this
Oi Douglas i welded them extensions on so no problem with them ever coming off again fully welded top & bottom
thanks steven
