engines being ran in can it be done on dyno?
Old 25-02-2005 | 11:28 AM
GARETH T's Avatar
GARETH T
running in be done on a dyno
yes
Old 25-02-2005 | 11:30 AM
Yes you can run an engine in a rolling road (i assume you mean that NOT a dyno?)
racers do it all the time.
Old 25-02-2005 | 11:37 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Engine dynos have a run-in program, so no probs. But as you say, the fuel cost / dyno time would be horrendous .
Old 25-02-2005 | 11:48 AM
Originally Posted by * Rudey *
ahhh got em mixed up cheers chaps know of any chip?
I cant think of a set of rollers who would say no to running an engine in, its easy money from their point of view.
As mike says, you actually do it on a program which varies the speed up and down etc, it can actually be more effective than an equal amount of time on the road.
Id want to still see at least 3 hours running though probably for a road engine, then start mapping it at part throttle and lower rpm so that it gets some extra time before its actually fully under load.
Old 25-02-2005 | 11:49 AM
gtir1281's Avatar
gtir1281
yes you can run it in on a dyno had a mate that was going to have his gtir engine run in on Norris Designs was going to be about Ł400 all in i think
john
Old 25-02-2005 | 11:51 AM
Ive neve done it myself, so cant comment on the costs, but 400 quid on a 4wd rolling road sounds pretty reasonable to me.
Nice to be able to monitor everything as its running in, plus you can still be doing some basic mapping at the same time to ensure its running in just right and not bore washing which is a common mistake people make with "safe" running in maps.
Old 25-02-2005 | 11:52 AM
Lee Reynolds's Avatar
Lee Reynolds
get it in the air on axle stands rudey and do a 1000 miles in the garage
Old 25-02-2005 | 11:58 AM
Kev H's Avatar
Kev H
Is it not better for an engine to be run in on the road ( real world driving, not motorway ) to ensure proper bedding in of the rings etc?
I know Rudey's circumstances dont give him much choice, was just wondering.
Cheers.
Old 25-02-2005 | 12:03 PM
Cheers.
No cause on a road you cant control the loads its under as well as you can on the rollers.
You can wind it up and down the revs at will, and vary the load against it etc fully on a set of rollers.
Old 25-02-2005 | 12:22 PM
Šhatter Box's Avatar
Šhatter Box
rudey give me ur car i run it in for u then i pop it into grove for u saves u all the trouble a lol
Old 25-02-2005 | 12:25 PM
cossiechris's Avatar
cossiechris
Rudey, not sure where you are based fella, but Northampton Motorsport offer this service, they're running my Mark1 in on their rollers in a few weeks
Their cost is based on an hourly rate as far as i know and he's looking at 3hours for the Mk1.
Old 25-02-2005 | 12:32 PM
cossiechris
I think the running in depends on what work it's had done to be honest. He recommended that period for mine. Now you got me thinking.....
Old 25-02-2005 | 12:36 PM
so this 1000 mile std run in milage that im led to beleive must be done? is pony poo? how many miles would an rr run it for ya think 3 hrs would get you around 150 miles ? my last engine was ran in for 3k
Depends on the engine, and specifically the piston to bore clearances etc, and how its going to be used.
For a race engine with the piston slopping around the bore like a 16 year old lad up a prostitute, 50 miles is plenty, for a road going engine with tight tolerances i always go for 500 miles very fussy, then 500 miles steady use, then 1000 miles of not thrashing it.
Old 25-02-2005 | 12:37 PM
cossiechris
That must be why i only need 3 hours then Chip lol, ah the joys of homebuilt engines ! PMSL
Old 25-02-2005 | 12:45 PM
Stu @ M Developments's Avatar
PassionFords Creator
Running an engine in is probably the most controversial topic ever and there appears to be no definitive answer available.
I personally supply my engines with a written running in and oil change program of bring to me for fuel and timing setting then a 1000mile step by step running in procedure after which they are to be returned to me for the boost and fuelling setting up.
Old 25-02-2005 | 12:55 PM
K3V HA's Avatar
K3V HA
but once license is back landspeed records in public places
Hucknall bypass??
Old 25-02-2005 | 12:56 PM
Mike Rainbird
Caraholic
john
Chip,
That's on their engine dyno .
Old 25-02-2005 | 05:41 PM
Billabong's Avatar
Billabong
does harvey do it?
Rudester, he obviously uses the engine dyno run-in programme before any mapping takes place on a freshly built engine so it's possible. I know the engine dyno is quite busy, and I'm not sure if Harvey has the looms etc. to put a CVH on the dyno, but it's worth a call. The only downside may be cost, but you could also get the engine mapped by Ahmed at the same time to make full use of the dyno time/cost?
mk22door
49
26-03-2022 07:15 AM
manuel boeckx
13
03-10-2015 02:29 PM
Chas
21-09-2015 08:57 PM
Anutternutter
21-08-2015 06:07 PM
yawiejon
15
09-08-2015 06:36 PM
Quick Reply: engines being ran in can it be done on dyno?
