Mondeo 1800 graphite Duratek engine
Hi had a problem car has engine management light on,is missfiring all over,stalls on idle,mileometer needle rises when reving up,have fitted new plugs and leads,please help
help with coil pack
hi thanks for your help is it hard to change coil pack diy have ordered one can you advise Also have a mate lending me the data reader is the port the silver like box it has a plastic black grill cover over front with a small bolt to remove.
Coilpack is only 4 torx bolts to change. The 16 pin diagnostic plug is near where your knees would be, have a look just under the dash, it slides downwards. Nothing needs to be removed to access it.
Hi changed coil pack was no different put old one back on now won't start just turns over,had to put jump leads on still won't start,on benefits can not afford garage
