fuel pump problem?
Old Feb 23, 2012 | 05:39 PM
neilrev's Avatar
neilrev
Default fuel pump problem?
hi all.
a mate of mine has a mk4 xr3i which refuses to start. he said the fuel pump was little noisy so he always knew when it was pumping.
he said that he hears the pump prime when the ignition is first switched on but can't hear the pump running when cranking. is it likely to be the pump or relay? if it is the relay is it the same as the purple one on an rs turbo? thanks, neil
Old Feb 23, 2012 | 05:42 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
see where is not getting power then trace it back untill you find power, easy
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dlwarrior
Aug 5, 2015 10:19 AM
