what power would you see from...
2.0l YB 4x4 sapphire
6 long stud block
ported and polished head
BD14 inlet cam std exhaust although he is in talks with someone about a one off profiled cam design?
pocketed pistons
swedish inlet
GT3076 HTA with 44mm tial external wastegate
ARP Rod bolts
lightened flywheel
hydraulic clutch
oppliger big tooth straight cut gearbox?
6 long stud block
pocketed pistons
swedish inlet
ARP Rod bolts
lightened flywheel
hydraulic clutch
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
The nut on the end of the shaft in front of the compressor wheel is modified into a 'bullet' shape, helping the flow into the extended tip of the wheel.
The bearing core is a motorsport metal caged item too on all the 30HTAs.
Gary at APT has had some really good results with them on 2.0 evo engines, here's a graph he sent me a while ago:
And guess what boost it did it at? (Power at the wheels in this one!)
deathrider666
28-09-2015 06:12 PM
