Fiesta Durashift ECU problem (UPDATE)
Old 11-02-2012, 02:34 PM
Sticky.
Sticky.'s Avatar
Default Fiesta Durashift ECU problem (UPDATE)
Can these ECU's be repaired? Wife's car is a 1.4 semi auto fiesta. It wont start & it's showing it's stuck in 4th but it's nuetral. Tried the shift actuators & wiring loom & all is ok.
Anyone had this problem or got the ECU's repaired?
Old 11-02-2012, 08:20 PM
Rick
Rick's Avatar
Have you had it code read mate?
Old 11-02-2012, 08:54 PM
GVK.
GVK.'s Avatar
Not seen any probs with these in the dealers, did quick Google and found this
http://www.fordownersclub.com/forums...-problem-easy/
Old 11-02-2012, 09:40 PM
wide ka
wide ka's Avatar
Commen for clutch or shift actuator, one is about Ł500 the other Ł800 iirc
Old 12-02-2012, 06:37 PM
Sticky.
Sticky.'s Avatar
Yes mate, says clutch selector but it's not as had them checked
I saw that & went to do it but they moved freely & not seized
It's none of them as it's been into a garage & had 2 sets tried on. It's defo ECU related.
Old 12-02-2012, 08:43 PM
James
James's Avatar
Thats suprising, out of the three semi-autos i know of locally two have issues with seized motors.
I would imagine someone can repair the modules but i've no idea who. iirc it's a bosch unit so i would assume you could get a reman one from a bosch dealer?
Old 14-02-2012, 04:00 AM
B19 JUB
B19 JUB's Avatar
if it is the ecu then it will need to be synchronized and positions set up as it has the built in master cylinder so needs neutral position and gear selectors initiliazed
Old 07-03-2012, 06:15 PM
GVK.
GVK.'s Avatar
I spoke too soon, got one to look at tomorrow
Old 30-03-2012, 03:29 PM
Sticky.
Sticky.'s Avatar
Update:
Can someone help or shed any light what im doing wrong?
The car has had 2nd hand actuators & ecu, we've had the car running & will select gears when the ignition is on stage 2, the car will also drive forward (1st & 2nd) but wont go into reverse. The clutch has been bleed up, but when it goes on the IDS to learn the procedures, it will not complete & puts the transmission light back on.
I know the actuators are 2nd hand but they both work...
Any ideas?
Old 31-03-2012, 12:42 PM
B19 JUB
B19 JUB's Avatar
make sure they are 100% correct part numbers for your vehicle.can be a real issue if not right
Old 31-03-2012, 09:29 PM
Sticky.
Sticky.'s Avatar
All part numbers are the same mate.
Old 31-03-2012, 09:50 PM
GVK.
GVK.'s Avatar
Has the correct tyre size and final drive ratio been flashed in the parameters section of 'module programming' ?
Old 31-03-2012, 09:57 PM
Sticky.
Sticky.'s Avatar
I'm not sure mate, I'll ask that question on Monday.
Old 26-05-2012, 03:54 PM
Sticky.
Sticky.'s Avatar
Would anyone know how easy it is to convert to manual?
Old 16-07-2012, 07:03 PM
Pudnpepsi
Fix or repair daily....
Pudnpepsi's Avatar
Paul did you sort this? the wifes one is doing the same thing.. and i cant find a ecu anywhere!
Old 16-07-2012, 08:29 PM
Sticky.
Sticky.'s Avatar
Yes I sorted it mate, its being converted to manual
You won't find a ecu anywhere, only place is fords.
Old 16-07-2012, 08:40 PM
Pudnpepsi
Pudnpepsi's Avatar
how hard is the conversion as i may do the same thing. any help mate would be awesome. L
Old 17-07-2012, 07:24 AM
Sticky.
Sticky.'s Avatar
Peddle box
Gear linkages
Folk and clips off a manual gearbox (semi auto box stays in)
Gear stick and cradle
Pipes from the brake resivour to slave cylinder.
Old 17-07-2012, 07:32 AM
Pudnpepsi
Pudnpepsi's Avatar
Nice one Paul. What happens about the inhibitor? Lol
Old 17-07-2012, 07:46 AM
Sticky.
Sticky.'s Avatar
It's in the process of being done mate. I know you have to kid the ecu and put a lead direct from the starter motor to get it going and need to blank the transmission light off.
big_Rad
15-09-2017 09:36 AM
manuel boeckx
13
03-10-2015 02:29 PM
Stu @ M Developments
41
21-08-2015 06:47 AM
coozer
Ford Focus Range
15-08-2015 10:26 PM
gingerturbo
11-08-2015 09:44 PM
Quick Reply: Fiesta Durashift ECU problem (UPDATE)
