FAO: any one with a zetec turbo
Just need some help I'm running a tubular manifold to mount my turbo to one side of my engine and i was wondering where i would put my oil return front or back of my sump. Any help would be great.
if u run the manifold with the turbo over the gearbox put it at the side?
No real drama either way - the Zetec's well baffled. Need to make sure the return is as close to the running oil level as possible without it being affected by cornering surges. In practice a central location (front-middle or back middle) at the top of the sump/bottom of the block webbing is fine.
There's a ~10mm bolt on the front of the Zetec-E that can be drilled out to accept the 18.2mm ERST oil return (an 18mm hole should give a good tight fit).
/al
