Fiesta RST wheel querie
Old 07-02-2012 | 02:12 PM
STeve's Avatar
Moderator
Default Fiesta RST wheel querie
I have a FRST running escort cosworth wheels with escos front brakes too, and my question is will normal 15" FWD escort gti/rs2000 alloys be ok and clear the caliper etc as I dont have any here to try, as it saves me buying a set and find out if they work or not, as I know with OE calipers it would work but its with escos ones thats got me curious
Old 07-02-2012 | 02:45 PM
AndyKam's Avatar
AndyKam
15's do fit around the cossie brakes its just the offset that i'm unsure about, but that can be adjsted with spacers. I had the same brakes on mine years ago with mk5 rs2000 wheels but had to use spacers as the they caught on the caliper when new pads were fitted.
Old 07-02-2012 | 03:05 PM
STeve's Avatar
Moderator
right so prob need 3 or 4 mm spacers then to use normal FWD alloys then , thanks
Old 07-02-2012 | 04:53 PM
Brendan's Avatar
Brendan
struggling with reality
I have A FRST and use sierra cosworth 4x4 brakes I am using 15" team dynamics pro race alloys, they are either an 35 or 40 off set ( I can find out but it will take time!) these work fine there is a little scraping on full lock but other than that work fine.
Old 07-02-2012 | 05:02 PM
Oranoco's Avatar
Oranoco
Should work fine. Clearance may be tight. I ran ST150 brakes under 15" TSW Stealths and they were tight.
One thing's for certain, it'll drive a thousand times better off the Cossie rims
Old 07-02-2012 | 05:16 PM
STeve's Avatar
Moderator
cheers for the replys guys as a set of 16" rs7s will be going on in a few months time once refurbed, but just want to get the escos ones off now and run it on 15s until then
massivewangers's Avatar
massivewangers
I would have thought it would be ok. I had a MK2 Orion years ago with 4x4 Cossie brakes and had no issues with S2 RST rims or Wolfrace Voodoos.
Old 07-02-2012 | 05:18 PM
fogulbennett's Avatar
fogulbennett
I have mk6 escort with 4x4 front break setup they fit under mk6 rs2000 wheels with a 3mm spacer with a little shave off caliper and pads
Old 07-02-2012 | 05:26 PM
STeve's Avatar
Moderator
nice one chaps, just trying to avoid using spacers or shaving caliper as the 15s will only be temp until the 16s are refurbed
Old 07-02-2012 | 05:50 PM
massivewangers
I think you'd be fine with GTI wheels mate. They seem to be ok for clearance.
Old 07-02-2012 | 05:58 PM
STeve's Avatar
Moderator
thanks for that fella
Ben26's Avatar
Ben26
I had a set of 15" rs2000 wheels on my fezz, then i upgraded my brakes to cossie 4x4 set up and they would not go on unless ,what looked like a heafty spacer was needed its because the spokes roll in when they join the rim quickly.
The pads where brand new as well
16" mondy wheels with a 4mm spacer is now spot on
Old 07-02-2012 | 06:03 PM
daveb_lives's Avatar
daveb_lives
my comps were 15's with at et35 offset and cleared escort cossie brakes without trouble.
should be fine IMO
dave
Old 07-02-2012 | 06:12 PM
massivewangers
RS2000 wheels are shite for brake clearance. They will go over 280mm brakes, but you need spacers.
GTI wheels don't have those problems, as the spokes go to the edge of the rim, rather than having a dish.
Old 07-02-2012 | 07:01 PM
STeve's Avatar
Moderator
we are fitting sierra saph 15" lattice on them for a few weeks so this should be ok im thinking
JoeyBoyden
04-01-2024 03:36 PM
Chas
21-09-2015 09:57 PM
Billy_RS
15
05-09-2015 01:04 PM
A.t.p
15-08-2015 12:37 PM
dlwarrior
05-08-2015 11:19 AM
Quick Reply: Fiesta RST wheel querie
