Info on zetec conversion please
My escort is currently a 1.3 and im wondering what drive shafts, hubs, gearbox and so on i will need to run a standard 2.0 zetec? Im hoping to just buy a mondeo and stripping it so shall i keep all the stuff from that or are they wrong length/sizes?
Any info would be greatly appreciated
i too am wanting this conversion for my 1.3 mk4. i think we need the rs turbo gearbox with lsd(although not essential)standard 1.3 will work, need to go for the early non pats ecu. Passive Anti Theft System(immoboliser),rs turbo petrol tank.
the 2.0 requires modification to the chassis i think but the 1.8 will go straight in. i'm still looking into this cus i want to start building a zetec to go in mine
big floppy donkey dick
in no way shape or form will you need to mod the chassis to fit a zetec,
i have seen some MORON section his chassis leg as the engine didnt go in from above, it WONT!
early non PATS 2.0 ecu esential
any mk3/4 (whatever model your car is) gearbox is fine and will do but agreed, LSD prefered.
use XR3i/RS Turbo/ 1.8d driveshafts for reliability
1.6EFi flywheel with modded holes and bolts
uprated clutch advised, not essential tho
CVH alt bracket, Escort sump, oil pump and pickup, waterpump+pulley if a 2.0 engines used and special belt
chop n change water hoses, this is fun
fit fuel tank if not XR3i/RST
make exhaust
thats it!
vrooooooooooooooooooooooooooooooooooooom
make exhaust
thats it!
CVH alt bracket, Escort waterpump+pulley if a 2.0 engines used and special belt
make exhaust
thats it!
make exhaust
thats it!
Johnny Knoxville
30-09-2015 07:21 AM
SMILER258
28-09-2015 09:04 AM
