Passenger door lock MOT Fail?
Hi all,
I know this has been covered in the past but with the recent MOT changes I'm after some upto date clarification please.
My mk1 focus is due for its MOT soon but the front passenger door has decided not to lock and unlock with the central locking. It locks and unlocks manually from in the car, both internal and external handles work and the door shuts securely. The wording for the front doors I have found is
"Both front doors must be openable from the inside and outside and all doors must latch securely."
Pass or Fail?
Now to me this means my focus will pass on this lock issue or have I missed something?
Thanks in advance.
Phil
Pass or Fail?
Thanks in advance.
Phil
The passenger front door opening from inside and out has always been a testable item
It is rear doors that have now been added to the MOT
Note:- A vehicle where the tailgate is or can be used for access to the rear seats then this is also a testable item
The VOSA official I recently had the pleasure of a 2 day refresher course with stated to those on the course that "if a vehicle has central locking that clearly does not works on 1 (or more) door but otherwise operates correctly then this is a FAIL under the new regs"
Never said it wasnt ?
Yeah I know thats what I said
Just to clarify
Rear = Tailgate or rear loading door on a passenger carrying vehicle
Rears = Passenger nearside and/or offside rear
Also it has never been part of the MOT to test the opening and closing of the Passenger rears they were only added in Jan 2012
also if the outer door handle doesnt open the door, but interior door handle does, then just leave the windows open so the they can reach in and open thedoor the from the outside.
ive done that before lol
I've disconnected a motor on the back door of my focus as it would intermittantly not unlock, and then wouldn't release the dead locking.
if the motor doesn't unlock it, just manuallu unlock it prior to the test
If N/S door works as you described (ie opens from inside and out using the "factory" door handles) and everything else on car is fine then personally I would pass and advise regarding CD Locking - where it becomes a problem is if a car cannot be opened when CDL fails and dead locks any door (if that makes sense !)
I've got a month before she runs out of test and got to do a service and check over at the weekend then book her in so will try to replace the lock before the test anyway to be on the safe side...not to mention its a pain in the arse!
Cheers All.
Rear passenger doors have always been a tested item and it hasn't just came in in January, a rear door must be able to be opened from either the inside or the outside and a front door has to be able to be opend from both inside AND outside. If a tailgate doesn't open weather it be able to be used as a passenger access or not if it doesn't open it's a fail and a reason to abort the test same as a bonnet not opening
QUOTE=RS2000CUSTOM;5798497]Just to clarify
Also it has never been part of the MOT to test the opening and closing of the Passenger rears they were only added in Jan 2012[/QUOTE]
Nearside and Offside rear passenger doors opening and closing have not previously been a testable item ever since I started testing in 1989
Heres the wording in the 09/11 Special Notice advising testers of the changes to take place in 2012
New RfR for any passenger door unable to be opened from outside the vehicle using the relevant control.
The above is taken from here - http://www.dft.gov.uk/vosa/repositor...ce%2009-11.pdf
last year a car comes into your station , both rear doors are hanging open , and wont stay closed
pass or fail ????????????
Please show me the Pre 2012 fail criteria for a rear o/s or n/s passenger door that does not open or close - you wont be able to it does NOT exist
The only applicable fail criteria pre 2012 would "in your case of 2 hanging doors" be the security of any part of the body or its associated fixings that are likely to cause harm or are a danger to other road users
Boot lock
Sorry to hi jack this but where would I stand if I took my car for an mot without a boot lock fitted you can still open and close it by sticking your finger in the hole and pushing the lever, it's a mk1 escort would it pass or fail cheers
you havent answered the question dave , pass or fail ?
you should know if you've been testing since 1989
method of inspection , doors , 1 c
http://www.motuk.co.uk/manual_620.htm
rear door have always been part of the test and only required to open from the outside
front doors req'd to open inside and out
all pre 2012 off course
it would pass , as you can open it and it can be secured in the closed position
By hanging I take it you mean damaged and swinging loose and not secured in anyway other than the hinges !
Then I would (pre 2012) fail under the criteria of body security but remove doors completely and it would have to be passed
Note :- the link to the testers manual if you scroll down it has an issue date of 01 jan 2012
right then , and without splitting any hairs
dec 2011 , a 5 door hatch comes in to you for mot and o/s/r + n/s/r doors dont open
PASS OR FAIL ?
also regarding link to testers manual , obviously it will say jan 2012 as they were updated then , but you will know this anyway
how did you inspect rear seat belts operation and security , rear seat and seat belt mounting points , o/s + n/s/r inner sills and all other prescribed areas accessed when rear doors are open ?
these are some of the reasons rear doors NEED to open to perform an mot test in accordance with the testers manual
checking all doors , bonnet and boot can be opened are part of pre-checks to be
performed before logging a vehicle on for test
If a vehicle is presented in such a way that I an unable to carry out a satisfactory and meaningful test then I would abort the test but if I was able to complete all required test criteria then as stated i would pass and advise
A car is presented with 3 out of 4 wheel nuts missing on one wheel but the wheel trim covers the nuts so I can't see there are 3 missing
I pass it
Same scenario - I can't see they missing or get to the nuts to see if they there but I have a fail criteria listed for it
I stick by my "opinion" that pre 2012 there was NOT a fail criteria for the opening and closing of rear passenger doors and as with ALL MOT's it is the opinion of the tester concerned at time of test
I pass it
REFRESHER COURSE !
ffs , i thought it could'nt get any worse than pass and advise
I pass it
I pass it
mots are about rules , regulations , measurements and standards not opinions
your only making it worse btw lol
you are however correct about the wheel nut as your are not allowed to remove or dismantle in anyway , but you cant apply that to the door thing
As we were talking about a pre 2012 scenario then no need for a refresher it is history and has now been updated therefore the refresher course I took in jan 2012 will suffice for the next 5 years unless the Secretary of State changes their minds on any items
A wheel trim on a wheel has nowt to do with this obviously you wouldn't remove it to have a look that's just being silly. You would however open a door to check it's accessibility and for corrosion with in a prescribed area. Your some mot tester like. Think you've been doing it too long and are obviously going a bit dittery.
I pass it
I pass it
