Zetec Dry Sump help
Old 04-03-2012 | 06:23 PM
  #41
crazycage's Avatar
crazycage
looking at that the pump can only mount on the front or the rear of the sump same as the titan kit.
and it wont bolt to the bottom two bolts on the mtx gearbox.
Old 04-03-2012 | 06:40 PM
  #42
Luca's Avatar
Luca
Lukesville
Thought the same myself mate.
Old 04-03-2012 | 06:58 PM
  #43
lacey's Avatar
lacey
This is the pattern so far but won't be long for the finished item
Old 04-03-2012 | 07:03 PM
  #44
lacey's Avatar
lacey
The pump will mount on the l/h and r/h side ( fwd/rwd) and it is on the sump to keep it low to try not to mess up the std alt" set up, if you look at the back of the sump it has mounts for the adaptor plate to bolt on which will bolt to the bellhousing to give that bit more strength
mk3ste
17-10-2021 10:09 AM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
Iain Mac
30-09-2015 09:39 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
youngben
27-09-2015 09:37 PM
Quick Reply: Zetec Dry Sump help
