No spark! Trying to restart YB.
General question, what may cause having no spark?
Just changed my turbo, inlet, fuel rail, injectors and chip.
All of the electrical plugs have been reconnected, new spark plugs but the car will not start.
I pulled a plug lead off, put a plug in it and turned over the car with the end of the plug against the car body...there was no spark.
I knew it may take a bit to clear the air out of the injectors and rail, but when the ignition is on you can hear the fuel running through the regulator!, but i guess this is normal as the pump runs continuosly.
Any ideas what the problem maybe and how i can test to confirm the issue.
thanks
thanks
Air will in no way effect ignition, the pump does not run continiously as standard either!
It's most likely to be something to do with the chip thats been fitted I should think, you could always try replacing with your old one as a TEST.
Martin
Martin
I couldn't remember if the fuel pump ran to pressurise and then stop or not?
What (signal) tells the pump to stop and start?
Sure the chip is the right way around as i got DIVA to fit it for me.
If the CPS is faulty / unplugged when engine is trying to start then no spark will occur.
Try the old chip to see if it starts, then you will know for sure if its the chip or something else, process of elimination.
The crank signal has nothing to do with the fuel pressure, neither has anything else electrical, but the pump will not prime without a signal from CPS.
Martin
As I and others suspected then, yes CL is only applicable to L8/P8, maybe it's some sort of decryption problem.
What ever you do don't drive it like that, it was only suggested just as a test.
Martin
Martin
nipper.1
Ford KUGA
12
30-05-2022 08:39 PM
DixieTheKid
11
06-06-2020 12:20 PM
deathrider666
28-09-2015 07:12 PM
dange
Ford Mondeo Including ST
23-09-2015 01:11 PM
