What rear end set up on a mk4 rwd conversion ?
Old 03-02-2012 | 07:39 PM
Northants Ford Fan's Avatar
Northants Ford Fan
Default What rear end set up on a mk4 rwd conversion ?
Hi guys,
as per title which rear end set up would you go for on a Mk4 escort rwd conversion to get the best adjustablity without having to spend thousands ? As i'm looking into doing a rwd on my mk4 project, i'm not to worried about it not being ford but something that is farley upgradeable if need be at a later date.
cheers
Old 03-02-2012 | 07:59 PM
whizzisat114's Avatar
whizzisat114
nissan 200sx are cheap and easily upgraded at a later date only 4 mountings iirc
Old 03-02-2012 | 08:02 PM
Northants Ford Fan
whats the track width of the 200sx set up ? will it fit under the mk4 rear end and still give reasonable wheel selection ?
Old 03-02-2012 | 08:05 PM
whizzisat114
google them m8
Old 03-02-2012 | 08:12 PM
Northants Ford Fan
will do, which is the best set up the s13 s14 etc ?
Old 03-02-2012 | 08:24 PM
Northants Ford Fan
just googled it there is less than 5mm between the s14 and the escort rear track, so that's looking a good option now to find a s14 I can pillage for bits
Old 03-02-2012 | 08:32 PM
Turbosimpsons's Avatar
Turbosimpsons
Capri special. Its got an lsd aswell.
Old 04-02-2012 | 07:52 PM
Northants Ford Fan
any other ideas i should look at ?
Old 04-02-2012 | 09:33 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
Nope you got it right the first
Time mate , 200 sx would be my only choice !
Old 04-02-2012 | 09:35 PM
stevieturbo's Avatar
stevieturbo
C**t
What sort of power are you anticipating and what sort of usage ? And what diff ratio you after ?
Subaru STI 2001+ rear end ( from a 6speed car ) is available in either 3.54 UK, or 3.9 Jap ratios and is reasonably self contained.. Maybe not as easy as the Nissan unit though. Subarus arent overly wide either. But the brakes on that model are quite big, but the 6spd have the bigger stronger R-180 diff ( very similar to the Nissan )
Old 04-02-2012 | 10:08 PM
gjh's Avatar
gjh
BMW? Cosworth is done to death, maybe supra if you are going for big power, whatever floats your boat really.
jessie_rs
11
03-06-2019 04:57 PM
Wilsfoci
15
30-03-2016 10:26 PM
track.focus'd
12-08-2015 05:53 PM
Red_bull
09-08-2015 08:34 AM
Quick Reply: What rear end set up on a mk4 rwd conversion ?
