Petrol in a Diesel
Petrol in a Diesel
My old mans just put a tenners worth of unleaded in his 1993 escort non turbo diesel van, he then put £20 of diesel in with the unleaded thinking it will be okay and do it no harm?? It starts and that will it be ok ?
Thanks
Thanks
personally i would fill it to about 3/4 full with diesel so that it can slosh around and mix together when driving
it should be fine with just £10 worth a petrol in , if anything it will clean the fuel lines and injectors out
if he worried about it then run it until the 3/4 tank of mixed is gone then change the filter as all the crap in the lines will be trapped in the filter
he will probably find it starts and runs a bit better too ! , diesel additives are essential petroleum based anyway !
struggling with reality
up to 10% petrol and you down't have to worry at all! £10 won't get you more than about 7.5 litres so fill it up to the brim with derv and you should be fine just don't run it flat out and keep an eye on the temp! the up side is you wont have any cold starting problems!!!!!
Out of many, we are one.
If my old diesel can stomach 75% cooking oil your dads motor can stomach £10 of unleaded. Fill the rest of the tank up with diesel, then as time goes on continue to add to it with diesel. Should run a dream too.
He said its been ok, bit spluttery when first starting but ok once warmed up.
I advised him to change the fuel filter once hes ran it for a bit and all the unleadeds gone.
Thanks
Thanks
