General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hello peeps, well yesterday my wife came home from work saying that the heater was not working its best, i said i look on wednesday when she off, but tonite she just home from a 14hr shift and it was freezing and she had no heater this morning or to nite.
The car is running sweet as a nut ect.
what do you think the problem will be.
ok can you hear the fan wirr ing when you turn it on? does it blow any air at all? have you checked coolant in the engine? do the pipes to the heater matrix get hot?
I think it could be a block in the tubes to / from heater matrix or matrix itself, as they are normally indipendant of the water thermostat! can you easily get at the tubes supplying the matrix? if you can you can see if its blocked using air from a air line!
