st200 slight miss?
st200 slight miss?
hi again all one more problem i would love to sort out is the slight missfire or hesitation i have on my st 200 when i start to apply some throttle i get a few dead spots llike a complete stopeage of the engine for a millisecond hard to explain but like when you have a damp set of leads and you give the engine some power to pull and then a sort of miss hapenns ,it does also seem quite lumpy at times on tickover, now i dont know when it was serviced last but the leads do look ols as they have the writing wearing away on them,as for the plugs again dont know when these were changed,so could this be that it needs a service or does it sound like something else ,i will add the engine is exellent sounds smooth , any help would be great as id love to get it running a1 cheers
Spelling Club King!
It's common for them to suffer from ignition issues. Plugs, leads and coilpacks can all fail and give these symptoms. When you have problems it's wise to replace them in one go, otherwise you can 'push' the problem from one to the next.
The TPS can also give these symptoms. Annoyingly Ford won't let you buy the TPS by itself, and make you buy the whole throttle body at great expense. You can Google Mondeo (or Contour) SVT throttle position sensor and buy one from America. I did a few years back and it was £25 quid. Did take a bit of searching though.
Could be worth you logging into www.talkford.com and asking on there as there are a fair few ST200 owners.
Received 1,044 Likes
I would change spark plugs leads and coil pack.If you get the right size extentions for a ratchet you can remove the rear spark plugs without taking the inlet manifold off like ford say.
The Enigma
12-09-2015 10:12 PM
