series 2 running/performance question?
I recently brought a g reg series 2 turbo. When i brought it, it was running a 2.1 zvh but it was nackerd so i didnt drive it hard at all but i did notice it was quite slow, i didnt take any notice as i knew the engine was been swaped. So i replaced the engine with a bog std 1.6 cvh turbo item, ive never had a 1.6 cvh turbo b4 ive always had zvh engines so i didnt realy know what 2 expect. It is what i would call very slow, a friend of mine big in to hes turbos also says the same. Any way 2 cut a long story short, what im finding is no mater how much boost i run through it it doesnt make the car any faster (i know u carnt simply wack the boost up and job done) but some diffrence should be felt. does any 1 know what could b going on?
spec:
std 1.6 cvh turbo engine
pro aloy front mount
stage 3 t3
mongoose (3 inch bore) exhaust
chipped ecu
I know its not going 2 be "evil/rappid" but it should be faster than my missis 03 focus diesel.
Any help or in put would be a great help thanks. Rob
spec:
stage 3 t3
chipped ecu
A set up for mfi is very simple yes? I am a mechanic my self, the ing timing is set to 10deg advance and the co is set at 3.5%.
Its almost as if the engine is staved of air, it makes boost easly (way of my 30psi gauge)
It does sound like it needs a good tuning session
I dont use it running 30psi, it runs 10psi. I worded it wrong i ment it will boost up to 30psi if you max the bleed valve out (i no there wank i dont usualy use it its kept shut).
I do see waht your all saying about a set up and im not ignoring this advise i will b looking in to it. But it just doesnt feel like a set up problem 2 me, It starts first touch of the key, cold or warm and drives realy well its just epicly slow.
I think it may be the turbo as the old (forged pistons) engine was fukd as i said, 3 of the pistons where starting 2 melt down, i have been in touch with a turbo guy who says if it started 2 melt the exhaust impeller (which is very likley is forged pistons were melting), it would b like driving a n/a car. Sort of no bang from the turbo coming in but it will still make boost. Sounds just like what mines doing.
Sounds to me exactly a set up issue. Stage 3 T3 is a bit OTT for the rest of your spec. If the turbo is making the boost and not passing oil it's fine
Have you checked your timing belt marks just to erase that out of the question, also just check your plug gaps, and clean the air filter out too just basic little check really
yer the turbo makes boost and it doesnt smoke 1 bit. Its just feels very diffrent from other escort turbos iv had/driven. Its got the stage 3 on because as i say it was a 2.1 when i brought the car and that is what was on it. It doesnt feel like it has a turbo on it at all, theres no difrence btween been on full boost or not on boost at all. Its not very laggy 2 say it has a bigger turbo on there.
Yes i have done the basics, and i have put a timing belt on my self so ill say thats fine but it will double check. I was also told it could b because the exhaust is 2 big?
Whoever your talking to this about I would recomend not doing so any further as it seems they don't have a fucking clue!
I do see what ur saying and i will get it booked in for a set up, but it just feels difrent 2 any other set up related problem ive ever had b4. As said ill get it set up and see what happens.
muz
30-09-2015 08:29 AM
SMILER258
28-09-2015 09:04 AM
