nikasil liners in a cosworth
*** Sierra RS Custard ***
If you borewash the engine a lot (like with some forms of antilag) they are a lot better at resisting excessive wear from the rings onto the bores than the standard bored and honed finish.
Couple of different ways of doing them, sometimes its a very thin liner, sometimes they open the block right out and use much thicker liners that basically replace the hole center of the block.
2K isnt a bad ball park price , capricorn in basingstoke who incedently do most of maclaren f1's machining do nikasil liners to yb's ect ! they do it correctly I.E the block is machined correctly to accept the liners correctly so there eual thickness all around the block rather than squashed in so the bores go oval then bored to get them round and sometimes uneven bore thickness
You cant, you'd go through the lining, maybe Jay is getting confused with normal liners not nikasil ones.
Personally im looking to keep the torque down to around 200lbft and make about 300bhp, although I may let it make a little more torque in the higher gears possibly, wont make the final decision till im actually mapping it.
Kind of, I just like how flat torque curves drive on a FWD car, dont like a big surge in midrange torque and then dieing off at high rpm, can lead to wheelspin and then once you stop it spinning it then feels flat cause the torque has died off etc, sooner just have a more or less flat curve that just pulls cleanly through.
Will be a case of trial and error to decide what feels best.
sit boo boo sit
Got anymore info about your mates, im soon to be turboing a 1.8 vtec myself sop the more examples I see beforehand the better.
Have texted him for as much info as possible on it
cossie fan (unluckerly)
Whats a block spacer thats changes stroke and capacity got to do with some one asking about fitting nikasil linners
Plus when building a mega bhp engine 1 head gasket is enough to worry about why on earth would you wont 2 lol
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
The spacer becomes an integral part of the block with the liners going right through it, thus adding a lot of extra rigidity to the top of the block as well as increasing the height of the block to allow a longer stroke and longer rods at the same time.
![Name: escortmechanical013-1.jpg
Size: 78.8 KB](https://passionford.com/forum/attachments/general-car-related-discussion/175834d1502131792-nikasil-liners-in-a-cosworth-escortmechanical013-1.jpg)
Thats the block with the spacer on.
Its not some pikey RST ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
But if you did it that way, the piston rings would have to pass the first head gasket, as bear in mind we're talking nearly an extra inch here to increase the height of the block, not a spacer to increase the size of the chamber to drop compression.
![](http://img.photobucket.com/albums/v221/martin-reyland/escortmechanical013-1.jpg)
Ask him, he might surprise you with an answer, he isnt as secretive as some people think IME
It is possible to coat the bore itself straight onto the iron of the block, but I suspect the cost in doing so for a one off would be high.
p.s
Lots of modern ally blocks are nikasil linered as standard, including the bmw ones that went wrong a lot, lol
![Wink](https://passionford.com/forum/images/icons/icon12.gif)
Here's some pictures of mine, you also need 10 long studs and if you are running a 4wd coolant pump you will need that modified as well as the impellar will fowl 1 of the long studs in side the block.
![Name: IMG_0963.jpg
Size: 123.0 KB](https://passionford.com/forum/attachments/general-car-related-discussion/175835d1502131792-nikasil-liners-in-a-cosworth-img_0963.jpg)
![Name: IMG_0965.jpg
Size: 98.3 KB](https://passionford.com/forum/attachments/general-car-related-discussion/175836d1502131792-nikasil-liners-in-a-cosworth-img_0965.jpg)
![Name: IMG_0970.jpg
Size: 71.9 KB](https://passionford.com/forum/attachments/general-car-related-discussion/175837d1502131792-nikasil-liners-in-a-cosworth-img_0970.jpg)
