nikasil liners in a cosworth
Old 02-01-2012, 04:31 PM
  #41
J1mbo
B1mbo
J1mbo's Avatar
thats just machining
iirc liners are 200 and something£ on top each plus studs and oil jets
Old 02-01-2012, 04:46 PM
  #42
LHD220Turbo
LHD220Turbo's Avatar
Originally Posted by Chip
Lots of modern ally blocks are nikasil linered as standard, including the bmw ones that went wrong a lot, lol
IIRC, that was caused by high sulphur in fuel reacting to the nikasil liners.
Old 02-01-2012, 04:47 PM
  #43
Chip
*** Sierra RS Custard ***
Chip's Avatar
Yes thats correct mate, and hence wouldnt be an issue if you had the same block new today, as there is a lot less sulphur in fuels in general now.
Old 02-01-2012, 08:24 PM
  #44
graham c
graham c's Avatar
Originally Posted by ajamesc
Gasket between head and spacer then gasket between spacer and block i presume? Unless im missing some thing?
yep you were missing some think
they use them liners when spacing the block then machine it flat
Old 02-01-2012, 09:02 PM
  #45
RWD_cossie_wil
RWD_cossie_wil's Avatar
I have to wonder if it is really worth chasing figures on a YB that require this level of spending? Yes it is fast, but ultimatly the reliability, durabilty & pleasure of driving such an engine is far outweighed by the cost?
Old 03-01-2012, 06:47 AM
  #46
graham c
graham c's Avatar
this is why am stopping at 400-450 plus gas for strip. just for that resone will its cheap and should be more than reliable and should drive ok to
Old 03-01-2012, 07:35 AM
  #47
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
yep i missed something lol but still fitting the spacer has nothing to do with just fitting linners dose it
Old 03-01-2012, 07:42 AM
  #48
NEIL A
NEIL A's Avatar
Im sure we use to pay around £120 to get 2 stroke motorcross bike barrels re coated.
Old 03-01-2012, 08:31 AM
  #49
Chip
Chip's Avatar
If you apply the same logic, why even own an escos when for half the money you can have an evo thats a better car?
Old 03-01-2012, 04:01 PM
  #50
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Of course its not worth it but is anything to do with modifying an outdated Ford . Is it reliable well mine did 6k miles before an inspection because of a tapping noise . Bearing wear on No. 1 & 4 so we are addressing that problem with a dry sump system.
Worth it !! hell No but who cares you have one shot at life. Im motivated by records not common sense ..
Is it a pleasure well come for a ride, you may shit your pants but i will have a grin from ear to ear it borders on unreal
Ive lived the majority of my life, you lads should have different priorities so to most it wont be sensible or cost effective.
Old 03-01-2012, 04:13 PM
  #51
Joshy
Dreamer
Joshy's Avatar
Can liners be inserted into most engines? Block rigidity permitting?
jessie_rs
62
06-08-2019 09:27 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
28
08-09-2015 07:10 PM
Adam Graham
06-09-2015 06:04 AM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: nikasil liners in a cosworth
