who to do some electrical work on my escos..??? UPDATE!!
Old 21-02-2005, 06:55 PM
  #41
Ryan
Ryan's Avatar
as wes had says 2wd cars dont have the fuel and ECU relays in the fuse box, can someone confirm if escort do or not?
As you may be looking for something that isnt there dave
Old 21-02-2005, 06:56 PM
  #42
Ryan
Ryan's Avatar
oh and dave get MSN back this would be alot easier
Old 21-02-2005, 08:25 PM
  #43
Matt
Matt's Avatar
couldnt i just rewire a feed to the ecu? is it ignition based or perm?
im guessing the ecu retains memory so it will need a perm feed all the time.. but this activates the fuel pump etc...
not a permanent feed, its ign switched
http://www.derbyshire-rsoc.co.uk/cosworthmanuals/
read them pal (i cant lol)
Old 21-02-2005, 08:40 PM
  #44
DaveEscos
DaveEscos's Avatar
ryan, i will mate
matt... if its ign based then fuck it, cant i just take a 12v feed from the igniton to pin 20?
will i need to relay this feed.. if so.. why? and how!
Old 21-02-2005, 08:49 PM
  #45
DazC
DazC's Avatar
RELAY FOOKING 8 FOR THE LAST TIME!!
Relay 9 is the fuel pump relay...
And they're both in the fuse box.
Old 21-02-2005, 08:50 PM
  #46
DazC
DazC's Avatar
I am thinking you have a fuse box fault to be honest Dave....
Old 21-02-2005, 08:51 PM
  #47
Ryan
Ryan's Avatar
there you go mate
Top work Daz
  #48
DaveEscos
DaveEscos's Avatar
daz, calm dooon
are they numbered!
Old 21-02-2005, 09:11 PM
  #49
Ryan
Ryan's Avatar
Old 21-02-2005, 09:14 PM
  #50
RichardPON
RichardPON's Avatar
PMSL @ Dave.
I think Gavin from the Norfolk group had a similar thing on his Escort Cossie a few years back.
He ended up replacing the whole fusebox..........
  #51
DaveEscos
DaveEscos's Avatar
what are you laughing at!
well are they!
how do i know what relay is #8 and #9
Old 21-02-2005, 09:15 PM
  #52
DazC
DazC's Avatar
Yes, but the numbers are printed UNDER the relays.
8 and 9 are next to each other..
Old 21-02-2005, 09:16 PM
  #53
DaveEscos
DaveEscos's Avatar
top man Daz
and your next task at a later date is to teach me how to read fooking wiring diagrams
Old 21-02-2005, 09:26 PM
  #54
DazC
DazC's Avatar
The proper Ford ones are not easy!!
Old 21-02-2005, 09:28 PM
  #55
DazC
DazC's Avatar
Dave, check there is a good 12v on fuse 25 (switch on ignition). Make sure you have 12v going into the fuse and 12v out of the fuse...
This will narrow a few things down....
Old 21-02-2005, 09:42 PM
  #56
DazC
DazC's Avatar
Right, bottom of the fuse box there is a shat load of plugs. One should be labeled up as M3. This is the engine compartment loom. Within that plug there may be a 6 way section hopefully labeled M3BA. If it isn't labelled then there is a 4 way section at each end of the whole plug, one with big terminals and one with small. The 4 way with small terminals has plug M3BA next to it. There is 1 free space in that 4 way plug and next to that free space in the 6 way plug (M3BA) is your Management live feed output from the fuse box (should be black/red). Obviously this should be a good 12v when the ignition is on and 0v when ignition off.
Old 21-02-2005, 09:45 PM
  #57
DaveEscos
DaveEscos's Avatar
bloody hell, cheers Daz, i shall 'attempt' that tomorrow
Old 21-02-2005, 09:46 PM
  #58
Benn 304R
Benn 304R's Avatar
Get Jim Galbally on the job
Hope you get it sorted m8
Old 21-02-2005, 10:16 PM
  #59
DazC
DazC's Avatar
Also, there should be a wire linking 2 pins together. One pin which is in the middle of that M3BA 6 way plug and joins to one of the pins on the larger 4 way section (M3BB). It should be a red wire.
That should also have 12v on both pins. This wire is the MAIN feed to the fuel pump relay and ECU relay and should be live all the time
Then the pin between the one for main ECU feed and this link on M3BA 6 way should also have 12v on it. It should be a black wire.
Final thing I can see is the ignition feed to switch on the ECU relay. This is on the NEXT 6 way plug section which is basically in the middle (M3A) of the whole plug. It should be a black wire and is in the same position as the ECU feed was (in the corner of the housing) in the first 6 way plug. That should be a 12v ignition feed.
BlakeMoyle
01-09-2015 02:24 PM
ar4ibaldo
Ford Focus ST
18-08-2015 04:24 PM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
jimmy oldskool
04-08-2015 07:06 AM
Quick Reply: who to do some electrical work on my escos..??? UPDATE!!
