Welding Plates over PCD holes and Re-drilling Steel Wheels?
Just a quick one
ive bought some 15x9 wellers for my e30 and there in the big 6 stud 4x4 fitment.
i want to weld a plate over the existing holes on the front of the wheel im not to arsed about a weld being visable on the rim. then i can "plug" the existing mounting holes from the rear then re drill them
i know this has been done before, and if people can cut a steel wheel in half "band" it then weld it up then im sure doing this shouldnt be a problem either
so me question is does any know anyone who can do this for me?
if not i can get the plates welded over at a fabrication shop, then i just need a company who can accuratly re-drill my wheels so there central. anyone know anybody who can help me out?
cheers
cheers
i know it doesnt help u fella but theres an engineer near me who widened the hub holes on my audi rims.was chatting to him and he has done that before for people where they bought different wheels.instead of a plate he welded up the holes and drilled new ones.do a google for engineers in your area
you would stand a lot better chance of getting the plates central to wheel if you either water jetted or laser cut incorporating both hole centre,s so you could bolt on the new bolt pattern weld around the plate then take the bolts out of the holes you do not need then plug weld them .
would be extremely hard to just weld & drill a plate in the right place .
worth buying some spacers with the correct pcd for the new wheels
then you can use them to mark the new holes.
if you get a proper hubcentric spacer you could weld it to the wheel?
What about cutting the whole centre section out of each rim and welding in that from a steel e30 rim?
I would imagine it might be a little time consuming, but something you should, in theory be able to get right yourself if you are careful. You could make a basic jig to ensure you get everything level and dead centre.
Tom
Tom
absolutely no imo, all steel wheels are pressed out for the holes i had the same issue recently with 3.75" pcd wheels i had to just get small triumph steelies and use them, just get the proper wheels to fit or get some proper hub centric adaptor spacers.
To the OP
A few people on the transit forum have used landrover wellers and re drilled because of having a very similar pcd but these wheels you have will havea huge centre bore which will make re drilling impossible?
I can't see why you couldn't have a metal plate same thickness as the wheel welded over the front? It could also be welded on the back inside every nut hole too for extra strength. You can also have the right centre bore drilled too.
It might end up costing a fair bit in the end though and they also might take some balancing!!
Gavin.
If you're wanting to run bigger wheels on the front of your dragster the mgf and mg tf have the same pcd.
To the OP
Gavin.
To the OP
Gavin.
14000+ post superhero
if they can put men on the moon im sure welding a wheel up and redrilling within balance wouldnt be beyond a decent professional engineers ability. no reason why it would be unsafe if done right but id guess it might cost a bit.
I dont understand why people buy wheels they know wont ever fit, then come up with such stupid fucking ideas to try and make them fit.
Just buy a wheel that fits !!!
What next, you'll start welding brake discs together ?
cheers for the comments guys, im not intrested in the "it carnt be done" comments as i know it can as its been done.
i wont be doing any cutting just welding a new plate over, plugging the holes and re drilling so there will be no strength loss as i wont be loosing any material
banding wheels isnt a option as its expensive for what it is and they wont be as strong as wellers.
imo this must be safer than banding provided there drilled properly
rog
04-09-2015 12:10 PM
borboyous
22-08-2015 11:17 AM
