Is a garrett t28 turbo good for my 2.0 zetec build ?
Old 04-11-2011 | 01:15 PM
stevealien's Avatar
stevealien
Default Is a garrett t28 turbo good for my 2.0 zetec build ?
Ok guys
Today I got a garrett t28 turbo from a Nissan 200 sx.
A/r 60 m24 is stamped on the housing.
Looks like a beast compared to my t3 I have currently.
Is this ok for my 2.0 blacktop zetec turbo build ?
I appreciate it might be too big to fit behind the rad so I'll do a over the gearbox manifold conversion.
Any advice appreciated as always fellas
Old 04-11-2011 | 01:28 PM
wilky's Avatar
wilky
good for around 280 bhp mate with a 360 bearing ,the nissan pulsar with the .86 exhaust housing is the one to go for has a bigger turbine and don't seem to run out of puff topend
Old 04-11-2011 | 03:27 PM
stevealien's Avatar
stevealien
Thanks for that wilky.
Is it better suited than my stage 2 t3 ?
Guy said he was running 360 bhp on his 200sx
Old 04-11-2011 | 04:04 PM
wilky's Avatar
wilky
i'd like to see it360bhp, comp wheels the same size as a 60trim roughtly
pulsar will clear 300-330 bhp,pulsar and 200 sx are the same size comphousing and wheel
turbine is different
yhey are real nice turbos mate
Old 04-11-2011 | 09:02 PM
stevealien's Avatar
stevealien
I wanted to get 300 bhp from my zetec turbo.
Could I maybe squeeze that out of this turbo ?
Old 04-11-2011 | 11:23 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
300bhp, perhaps a cossie 4wd turbo with 360 degree thrust bearing.
other than that, try a gt28 turbo.
Old 05-11-2011 | 11:23 AM
stevealien's Avatar
stevealien
Can I do anything to this t28 to enable me to get 300 bhp ?
I've bought it for a good price so don't mind modding it if possible.
Old 05-11-2011 | 12:12 PM
RS Grant's Avatar
RS Grant
Made in Scotland
I thought the standard T28 from the S15 Nissan was capable of over 300bhp?
Cheers,
Grant
Old 05-11-2011 | 12:13 PM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
yes have the pulsar comp and turbine wheels machined into it
Old 05-11-2011 | 12:32 PM
wilky's Avatar
wilky
as said a bigger turbine from the pulsar you clear 300bhp with quick spool up
i've only seen 280 bhp from a 200sx but some do say 300 bhp is posible ,it may be but a pulsar will piss it which is what you want to start with
Old 05-11-2011 | 06:03 PM
stevealien's Avatar
stevealien
It's from a s13 if that makes any difference
So I'm assuming it's better than my stage 2 t3 ?
Nobody seems to have commented on that question
Old 05-11-2011 | 06:24 PM
RS 5tu's Avatar
RS 5tu
S13`s didnt come with a T28 (unless upgraded)
Old 05-11-2011 | 07:38 PM
stevealien's Avatar
stevealien
Perhaps it was upgraded then. How do I tell if it is a t28 then ?
Old 05-11-2011 | 07:55 PM
RS 5tu's Avatar
RS 5tu
take the compressor housing off and measure the wheel diameter.
Ill try and find u a little more info.
Uk spec S13`s with a CA engine come with a T25 like u say it could have been upgraded or if off a import with a SR engine then it could be a T28
Old 05-11-2011 | 09:30 PM
stevealien's Avatar
stevealien
Thanks for all the helP so far guys. I'll try get some pics up if it helps
Old 06-11-2011 | 10:07 AM
wilky's Avatar
wilky
the one you need has a .60 comp housing and around 46mm inlet [inducer size]
s13 are smaller
Old 06-11-2011 | 10:17 AM
stevealien's Avatar
stevealien
Here's some pics of it.
Old 06-11-2011 | 10:39 AM
Fast Guy's Avatar
Fast Guy
Is there a little plate on the core with any serial numbers on?
Old 08-11-2011 | 06:24 PM
stevealien's Avatar
stevealien
I'll have a look next time I'm at the unit mate
Old 09-11-2011 | 01:14 PM
wilky's Avatar
wilky
looks like a nissan 200sx s14
Old 10-11-2011 | 01:35 PM
stevealien's Avatar
stevealien
Your right wilky.
I spoke to my mate and he said he got it off a s14.
Does that make much difference ?
Here's what's on the plate
Old 10-11-2011 | 01:59 PM
bluntys1rsturbo
Boost addict
yes its got a smaller exhaust housing and tubine than a pulsar t28, easily sorted though you could go for a .86 housing and pulsar turbine, or machine the pulsar turbine into the .64 housing you have
markk
02-12-2021 06:59 PM
mpilk
12-08-2015 09:40 PM
Quick Reply: Is a garrett t28 turbo good for my 2.0 zetec build ?
