why the fook do cossies
19-02-2005 | 12:30 AM
19-02-2005 | 12:33 AM
19-02-2005 | 12:38 AM
my mates series2 used to do the same but his was worse his didnt even attemp to turn over at least mine turns over but just wont fire
19-02-2005 | 12:42 AM
S2 do it due to the starter moter being under the turbo ( i think ) mine does it now and then when i take it out and punish it....
CheeRS
Craig
19-02-2005 | 12:55 AM
Quote:
CheeRS
Craig
3i's had a similar problem which was a starter motor location problem as well. Mine was a nightmare for that. I think I remember someone at the time saying it was near the exhaust manifold or similar.
19-02-2005 | 10:15 AM
mines always first turn no matter what conditions.....watch this it wont start today after saying that!
19-02-2005 | 10:19 AM
same here always works
19-02-2005 | 10:22 AM
Re: why the fook do cossies
Quote:
Originally Posted by Alps Pacino
because there is something wrong with yours
19-02-2005 | 10:25 AM
Um, they don't...
19-02-2005 | 10:37 AM
19-02-2005 | 11:28 AM
i know there is something wrong with mine, just wondered if somone could shed some light on it, o and i know other cossies that do the same thing so thought it might be a common problem
19-02-2005 | 11:35 AM
What do you mean when it wont start, does it turn over but not fire or does it just not turn over at all?
19-02-2005 | 11:51 AM
it turns over just wont bark up
o it only happens now and then probably about 5 times in about 8 months
19-02-2005 | 11:55 AM
19-02-2005 | 11:56 AM
cossiemen ,
19-02-2005 | 12:01 PM
19-02-2005 | 12:03 PM
both summer and winter mate
19-02-2005 | 12:06 PM
Is the engine management light staying on at all when it happens?
19-02-2005 | 12:07 PM
no everything is fine as it should be, just wont fire
19-02-2005 | 12:08 PM
okay, i'll see... was asking that cause mine, not me cossie but me fez, is having some startproblems when it's cold and wet outside,
so maybe there was a change yours had the same problem.
Don't know why it happens but i just deal with it...
19-02-2005 | 12:10 PM
I would say leads/plugs but not too sure
19-02-2005 | 12:11 PM
19-02-2005 | 12:12 PM
but if it was leads and plugs woulgnt it be playing up under load and in normal driving
19-02-2005 | 12:50 PM
As i said i'm not to sure, i suggested these as i couldn't think of anything else
They're probably still worth checking anyway
19-02-2005 | 01:50 PM
Ignition Amp is a common cause of this.
19-02-2005 | 02:11 PM
^^^ Word
19-02-2005 | 06:31 PM
_________________
would this make my rev counter slightly irratic at about 5k, o and will it affect the performance or effect the car in any other way stu
19-02-2005 | 06:33 PM
mine starts first time every time
DAN
gcfcos
59
06-10-2015 06:04 PM
XR4
Ford XR Range
01-10-2015 01:46 PM
A.t.p
29-09-2015 06:04 PM
cossie330
27-09-2015 05:13 PM
Russ Payne
25-09-2015 09:29 PM
