Air bag question!!!
Air bag question!!!
Does anyone know how to make the light go off? Mine has has all airbags i assume go off, the diagnotic machine says open circuit, can i remove a fuse or resistor etc to fool the car?????? Renault Clio
ok so i assume the light is an led or bulb on an 02???? Anyway to "break" the led if its that? It also puts the service light on so need to break or take bulb from that!!! Happy without the airbags as aftermarket awesome steering wheel and all leather retrim!
to edit the resistor works and actually fools the car to think it has airbags so light on then off after check!
yes phil.most car makers put a 10 yr life on airbags,we were just discussing this at work,woundering when it will come in to the test,who,s going to replace the bag on a 10 yr old mondeo so they can get an mot
cheeRS stu
cheeRS stu
Jan 2012 any car originally fitted with an airbag from new will have to be (a) present (b) the light will have to sequence as per manufacturers spec, all this info is automatically printed on the vt 40 for the tester verify its correct.
Surely only the drivers bag should be applicable? But aslong as the resistor fools the ecu i will fool the mot! The steering wheel i have came with a resistor!!!!
I have the og wheel with airbag so should be ok lol, but i cant see it coming in because of the scrapping situ, airbags are stupid money, and if older than 10 years they aint garanteed to work!
After market steering wheels with no air bag fitted on a car that would of had one from new will fail, it will mean alot of people will be swapping steering wheels for an mot
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
