stiff selector focus mk1
Old Oct 6, 2011 | 11:51 PM
cossie brad's Avatar
cossie brad
Default stiff selector focus mk1
Hi as said above drove a few mk1s now with this problem its stiff to move the selector and the return to neutral feels as though there is no spring there? Is there an easy fix or am I going to need to replace the whole selector? If I do need to replace it guessing I would need to go for a brand new one as most older focus's I have drove felt this way.
Old Oct 7, 2011 | 04:25 AM
It might just be cables. undo the cables from the gear box. Im sure there connected to the front of the gearbox and are hidden in a black box on the front of the g box.
Undo the cables and work the gear stick.If its still tight it should be the cables.
Check the linkage in the black box too cause i think they can seize up too.
Old Oct 7, 2011 | 08:24 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Cables went on my FRS and it felt like shit. Massive difference when fixed.
Old Oct 7, 2011 | 10:47 AM
cossie brad
How did you fix them? Did you replace them or did they need to be lubricated?
Old Oct 7, 2011 | 12:08 PM
martysmartie's Avatar
martysmartie
Correct, there are seven clips on the cover
Martin
Old Oct 7, 2011 | 01:39 PM
cossie brad
So if it is stiff with the cables disconnected can the cables be lubricated or do they need to be replaced? Where can you get them from is it just the dealers? How much are they?
Old Oct 7, 2011 | 03:02 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
The return spring sounds poxed, but is easy to change. The selector cables are straight forward enough, though you'll need a second pair of hands to hold the gear stick steady while adjusting them. Try this:
Take out the air cleaner box, remove the bolt on the drivers side of the engine fusebox, release the two clips on the other end and roll the fusebox forward.
Directly below will be the two selector cables.
The one with the white end is forward/back and the black end is left/right.
The cable ends are adjustable. My issue was with the forward/back motion (white) sometimes I'd have to give an extra shove forwards to get first.
The idea is that you push the orange button in all the way until it clicks into it's housing, you can then slide the cable in/out a litte.
You need an assistant to move things forward/back for a bit to make sure you have it right in your head. I needed to shorten the cable.
The orange button was stuck on mine but a quick squeeze of some pipe pliers freed it off.
I put the car into second, then I pushed in the button and she moved the lever forward (or maybe backwards, I cant remember) with the clip open the cable moves but not the head. she moved the lever very slowly and when it had shortened by two notches I released the clip and it locked.
Took it for a quick spin round the yard and it was perfect. it might take some trial and error, I think I just got lucky.
Old Oct 7, 2011 | 03:37 PM
Martin
Thank you.Most of us are here to help.
Old Oct 7, 2011 | 03:45 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Sorry I'm fucked if I remember the cost but I'd like to say they weren't that expensive. 30quid max?!
They were changed and not lubed.
Old Oct 7, 2011 | 05:24 PM
cossie brad
Cool thanks guys i'll take a look and see if that lot helps.
Old Oct 7, 2011 | 07:05 PM
SaphCos4x4_Dan's Avatar
SaphCos4x4_Dan
loves a good ham shank
There are two 10mm bolts under the heater box where the cables come through that are a right pain iirc
Old Oct 7, 2011 | 09:50 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
i changed a set of cables on my brother inlaws old focus there no to bad to change really, cost just over £100 from ford at the tym, dont know how much they cost now tho,
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
massivewangers
30
Oct 1, 2015 07:40 PM
richierich1986
Sep 18, 2015 03:29 PM
JamboRS
28
Sep 14, 2015 09:02 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
