New keys
Old Oct 6, 2011 | 05:53 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default New keys
Can you get new keys made and programmed for my car. i dont have the red key so is it still possible. its a mk6 escort
Old Oct 7, 2011 | 04:04 AM
B19 JUB's Avatar
B19 JUB
yeah u can.if u have just one key then u will need two more keys cut and programmed.just use the key you have as its first key as the red key wasnt anything special only the first key programmed to the car
Old Oct 7, 2011 | 04:28 AM
How do you program the keys. Do you put the coded key in the ignition switch ignition on the off again then put new non coded key in switch ignition on then off and then do the same for the other key.??????
Old Oct 7, 2011 | 10:31 AM
martysmartie's Avatar
martysmartie
I believe the red "Master" key is used to initiate "Learning mode" so the new key can be learnt. If you don't have or loose the master key however, you are in trouble as you need WDS to program them, in other words a job for Ford.
The exact procedure will be in the handbook, it's something like turn the key on and off four times in quick succession IIRC.
Martin
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
Flatlinedan
Sep 18, 2015 12:41 PM
NC53
Sep 13, 2015 03:05 PM
