Extra gauges
Old Oct 5, 2011 | 06:14 AM
cossie330's Avatar
cossie330
Default Extra gauges
Hi, probaly a stupid question but am looking to get extra gauges fo my saff cossie. What would you recommend as don't really know where to start, also what sensors etc ?
Old Oct 5, 2011 | 07:39 AM
john_p_b's Avatar
john_p_b
well what do you want to monitor? most have a boost gauge and oil pressure gauge. i personally have boost, oil pressure, water temp, voltage and afr.
Old Oct 5, 2011 | 08:36 AM
martysmartie's Avatar
martysmartie
Boost gauge is a given, oil pressure gauge is quite popular as well as a voltmeter.
It depends as said what you want to monitor, personally I find boost gauge and voltmeter is suffice, water temp is a good idea if wanting accurate information, also a AFR would be useful.
Martin
Old Oct 5, 2011 | 11:32 AM
Marc sierra's Avatar
Marc sierra
I'd also go for an oil temperature gauge.
Old Oct 5, 2011 | 11:42 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i have boost oil pressure and afr i think there the most important! also have an oil temp one i fitted to see if i needed an oil cooler
Old Oct 5, 2011 | 11:59 AM
Mark 3D's Avatar
Mark 3D
Moderator
As per above Boost and Oil Pressure are the ones i would always start with
Old Oct 5, 2011 | 12:58 PM
R4N SS's Avatar
R4N SS
ive got boost, oil temp and oil pressure waiting to go in mine.
Might even order the ACT gauge that rainbird sells as they are relatively cheap and small too.
Will eventually get voltmeter, water temp, and AFR
Old Oct 5, 2011 | 01:05 PM
Mark 3D's Avatar
Mark 3D
Moderator
F*ck me Ran its gonna look like the Challenger space shuttle control panel in your car!!!!
Old Oct 5, 2011 | 01:33 PM
R4N SS's Avatar
R4N SS
yeah i know. Dont need the center vents, the clock is shit as is the door open display thingy so going to replace them all with gauges.
oh yeah, also need to keep space for fans override switch, flamer switch and anti-lag switch
Old Oct 5, 2011 | 03:36 PM
Jamie@FastFord's Avatar
Jamie@FastFord
Jamie @ Fast Ford
Personally I think fuel pressure is always a good one, but everyone seems to forget it!! And then wonder why their 20-year old fuel pump and crusty fuel pump wiring causes the engine to melt! lol!
Boost and oil pressure are a given as said, but personally I'd suggest fuel pressure over volt meter any day!!
Old Oct 5, 2011 | 03:40 PM
ajamesc's Avatar
ajamesc
yeah but an afr gauge can show a fuel pump / pump voltage problem!
Old Oct 5, 2011 | 04:44 PM
Guinnless's Avatar
Guinnless
I've got boost pressure , oil pressure, oil temp, water temp, voltmeter & air temp at the throttle body.
Old Oct 5, 2011 | 05:06 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Boost, oil pressure, and AFR is all you really need. And some kind of engine monitor if you want to be really flash. You don't need a fuel pressure guage in the car, unless you want the inside of your dash to catch fire when it starts to leak. The AFR guage will tell you about impending fuel related doom anyway.
Old Oct 5, 2011 | 06:34 PM
cossie330's Avatar
cossie330
Cheers guys, was thinking of boost, oil pressure and water temp. Forgot about afr. Do the gauges come with sensors or do you have to buy all components separately?
Old Oct 5, 2011 | 07:54 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
I have fuel pressure, EGT, AFR, Volt, boost, oil pressure and a secs monitor
Steve
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
