Cost and Parts for a genuine 500bhp cossie engine???
Old 18-02-2005, 01:52 PM
  #81
Porkie
Porkie's Avatar
Mike is SOOOOOOOOOOOOO on the phone to Harvey right now!!!!!
  #82
Porkie, unfortunately im moving house so i cant come.
Clare has been nagging me to go along as well but its just not an option, if you'll let me take a raincheck on that though ill certainly take you up on it the next show instead.
Old 18-02-2005, 01:54 PM
  #83
Porkie
Porkie's Avatar
No fcuk off... it was a one time only offer
Old 18-02-2005, 01:56 PM
  #84
PMSL
At the end of the day, im not saying 8 injectors is wrong, thankfully the sort of failure that Doug had is uncommon.
Im merely saying that in my opinon, paying more money just to have twice as many potential points of failure plus an increased chance of not noticing seems like a bad idea.
However a properly installed and maintained 8 injector setup should be perfectly reliable in all but a very occasional case (dougs here for example), and like bosch_man says the actual injectors themselves (greens) are awesomely reliable.
Obviously if rainbird has a different view thats fine, but he doesnt seem to be explaining very well what he thinks the advantages are, he just seems to be playing down the disadvantages, its kind of like wathcing a politician on a "damage limitation exercise" at the moment.
Old 18-02-2005, 01:57 PM
  #85
Well that told me then!
* boschman mode *
Sorry ill just get my coat and fuck off then
STAMPS FEET
*/boschman mode *
Old 18-02-2005, 02:10 PM
  #86
Porkie
Porkie's Avatar
Old 18-02-2005, 02:18 PM
  #87
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Actually Chip I disagree with you 100%. The only scenario where having 4 injectors over 8 would be a saving grace would be if the failure to an injector happened whilst the engine was coming on boost and even then it would ONLY be a problem for the 8 injector set up if it was an injector that failed in the second rail (as you wouldn't notice that until too late ). This is because an 8 injector set up runs on 4 up to a certain boost level anyway, so below that you would notice a problem.
However, if you had an injector fail on either set up while on a high speed run, the heat build up that was already there would destroy the engine if the cooling effect of the fuel was removed in a catastrophic injector failure, be it completely (4 injector) or partially (8 injector) .
As to why I am an advocate of 8 injectors, for the same reasons Phil states earlier. He is almost quoting verbatum what I have heard Ahmed saying (so he must have been phoning Harvey / Ahmed as well ) .
Old 18-02-2005, 02:28 PM
  #88
Karl
Norris Motorsport
Karl's Avatar
Im sorry Mike but I disagree!!!
Your argument would mean that everytime you lifted off the throttle after a high speed run your engine would melt unless there was over run fuel! In reality very few cars have over run fueling activated much above 2000rpm, so why don't they all melt when you lift off after heavy load??
  #89
Mike, you arent disagreeing with me 100% at all, i agree with most of what you are saying.
failure at low boost is identical - YEP i agree
failure at high speed is identical - Kind of - still an issue but your chance of surviving it on four is higher, especially if its total failure, like Karl says no fuel is actually common at high speeds and is perfectly safe
Im not saying that 8 injectors is MUCH more likely to lead to a failure, simply that is it more likely, so why pay all the extra money just for a slightly higher risk of failure?
If you still think that makes me "THAT stupid" then you are welcome to your opinion, but there are certainly a hell of a lot of well respected cars that follow the same though prosses as me, like Rods, The norris design evo, and just about every other car really, multi injector setups arent used on those cars, and im positive that cost isnt an issue to them.
Old 18-02-2005, 02:42 PM
  #90
Mike Rainbird
Caraholic
Karl,
We'll agree to disagree on that one then . I've seen the results of engine's failing due to fuel pumps packing up or single injectors failing (on four-injector set-ups). It's not pretty .
Chip,
I think you will find that where people have an economical choice of running eight injectors they choose to do so (there are even 8-injector set ups for Scoobies etc). However, where packaging and the requirement of hugely expensive custom parts prohibit this, then people have no choice but to go with four.
This is my preferred choice, it's up to you lot what you want to go for (cheap-skates ).
  #91
Porkie
Porkie's Avatar
Karl is right, Chip is right
Mike is a cock
Its just that simple
Old 18-02-2005, 02:45 PM
  #92
Alg1k
Alg1k's Avatar
Old 18-02-2005, 03:03 PM
  #93
Mike Rainbird
Caraholic
Lee,
I'm so gonna make you choke on Saturday night - after the 14 hours you'll be begging me to shoot my load .
Old 18-02-2005, 03:06 PM
  #94
Billabong
Billabong's Avatar
Mike, you sick, sick man!!
Old 18-02-2005, 03:08 PM
  #95
ImaRacing 700
ImaRacing 700's Avatar
Mike is a cock
Im that simple
  #96
Disabled Account
Disabled Account's Avatar
Lee,
Old 18-02-2005, 03:12 PM
  #97
martinrs500labatts
martinrs500labatts's Avatar
yer but how about running TWO FUEL PUMPS!!
this has the same effect,
my old rs500 spec had
eight injectors and TWO fuel pumps.
so twice the chance of sudden low fuel and bang goes the engine,
lucky for me this is still rare and i had no problems at all,
the new set up will be eight injectors O DEAR!
AND FOUR FUEL PUMPS O DEAR O DEAR
still its all good fun,
is it imas time to tell us we should all be useing one massive fuel pump!
Old 18-02-2005, 03:15 PM
  #98
RichardPON
RichardPON's Avatar
Martin,
Is that spearate pumps for each rail, and two pressure regs, or two pumps into one line?
  #99
Porkie
Porkie's Avatar
Why not??? I do easily big enough. The simplest solution to a problem is normally the best way
Old 18-02-2005, 03:18 PM
  #100
martinrs500labatts
who know mate i am just the driver,
yer porkie, but i like lots of little bits to go wrong
it would be no fun if it did not break now and then
Old 18-02-2005, 03:22 PM
  #101
ImaRacing 700
I will only be using one fuel pump!!!!!...But 8 injectors WRC side by side style with a Swedish Plenum.
Old 18-02-2005, 03:25 PM
  #102
Porkie
Porkie's Avatar
My car would be ALOT more fun if it didn't break little stooopid bits all the time
Old 18-02-2005, 03:28 PM
  #103
Disabled Account
Young Phil, dont forget to aim all eight injectors at the INLET valves
  #104
Ryan
Ryan's Avatar
im doing the same as you phil but with 4 instead of 8
Old 18-02-2005, 03:34 PM
  #105
ImaRacing 700
Doug and dont you forget to connect all the injector plugs.
Old 18-02-2005, 03:35 PM
  #106
Porkie
Porkie's Avatar
same as me you mean then
Old 18-02-2005, 03:37 PM
  #107
ImaRacing 700
Ryan...i thought you bought the ZOO Motorsport one?
Old 18-02-2005, 03:42 PM
  #108
Disabled Account
Was'nt me
The injector clip in question was missing it's little nylon spacer thing (a see through flexable washer)....The clip as actually ON the injector, but not a proper tight fit without that washer
Old 18-02-2005, 03:49 PM
  #109
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Its the moisture seal Doug.
Old 18-02-2005, 03:55 PM
  #110
Disabled Account
Stu, thanks........
That moisture seal is the ONLY thing that we could identify as the likely cause of the damage..........I took all 8 injectors to a place with an Asnew tester/cleaner, they ALL flowed very close figures, and all were clean, with a nice even spray.....so not cloged up at all
Old 18-02-2005, 05:14 PM
  #111
Sausage
Sausage's Avatar
Interesting reading
So what benefits do the swedish style plenums give over an EECIV plenum,if any?
Do some of you not like T4's due to the lag,or is there other reasons?
Old 18-02-2005, 05:21 PM
  #112
Jon(m600)
Jon(m600)'s Avatar
Think T4s only flow upto 550brake, so for any more power you have to go to GT35 ect ect but i may be wrong
Old 18-02-2005, 05:29 PM
  #113
markk
markk's Avatar
mike you seam to quote top dollar for all your parts in this equation , where in realitly nearly everyone can get some sort of discount from somewhere or by using differant suppliers and yes i can read hence my comments , and you also seam to be in the dark ages for this '500' horse setup that the author actually asked for in his post
i know how much it costs , im not going to say how much i 'could' build one for or how much i 'would' build one for , but one thing is for sure it wouldnt entail alot of the parts youve listed my frieind
and as for the 8 injector setup, looks cool very dangerous
i too have seen the aftermath of one pump failure too , wasnt nice, if it was on 4 inj system the driver would have felt 'something' wrong and backed off the guys looses 25% of his fuelling on a four injector setup ( wireing/inj failure) or the guy that looses 12.5% of his fuelling , who is going to notice theres a problem first ???
oh and ..............................................
Old 18-02-2005, 08:52 PM
  #114
The best solution with regards to pumps is to run two pumps in parellel each of which with more capacity for flow than the system needs, then if either fails its still fine.
Thats kind of what ive got on my integra as lift pumps, two facet redtops, each of which is capable of flowing enough for what i need both feeding into a common swirl pot, so if either fail half way round a track session then the car is still fine but then on the output side i only have a single 044 pump where really i could have two in parrellel if i wanted to be totally over the top but seeing as its only 24" from my head, ill soon know if the bastard thing stops making a racket anyway, lol.
Old 18-02-2005, 08:54 PM
  #115
markk, sounds like you are "THAT stupid" like me too mate.
Seems to be a lot of us about!
Old 18-02-2005, 09:03 PM
  #116
markk
markk's Avatar
chip-3door,
indeed m8 - us - 'thick as fook'
Old 18-02-2005, 09:07 PM
  #117
DazC
DazC's Avatar
I prefer 4 injectors, single pump set up personnally for the simplicity and the reduced risk of molten pistons!
If your pump fails your car stops. If an injector fails, you have a misfire. Simple
If your pump has degraded, you risk melting. If an injector clogs, you risk melting.
With 8 and 2 pumps then the risks are doubled IMO.
Also a moded 4x4 plenum cost about £60. A pretty crude way of increasing flow but it is increased flow none the less....
Old 18-02-2005, 09:11 PM
  #118
markk
markk's Avatar
Also a moded 4x4 plenum cost abour £60. A pretty crude way of increasing flow but it is increased flow none the less....
oh cant believe your as stupid as us daz you know things have to be in multiples of £1000
Old 18-02-2005, 09:17 PM
  #119
DazC
DazC's Avatar
Multiples of 1k!? My Dad's car wouldn't be as fast as it is if they were in multiples of 1k!!
And yes! I admit it, I am a complete retard with no brain or common sense at all!
Old 18-02-2005, 09:20 PM
  #120
markk
markk's Avatar
DazC,
v.quick car that is to !!
Quick Reply: Cost and Parts for a genuine 500bhp cossie engine???
