H4 bulbs -.-
H4 bulbs -.-
when you turn sidelights on the main bulbs light up a but al be it dim can you cut a certain wire to disable that so you just have sidelights with no main bulb on
Thanks
Thanks
ah right then, thanks for that im doing a conversion soon so were see what its like with the different wiring loom in then and if the lights are still on i will do some more research
i did this on both my Escort RS turbos as i used led sidelight bulbs and they looked pants with the H4 bulb on.
no need, assuming this is a mk4 escort, there is a relay you can remove in the fusebox that has the same effect. when removed, sidelights are the 501 bulbs only, then dimmed beams are H4 as are main beam.
Thankyou
Received 1,044 Likes
What so cause we had some posh head lighy bulbs we had to drive around with them on.So all these boyos in the corsas and saxos with these head light bulbs have to drive around in day light with them on?
Steve Escos
01-10-2015 06:57 AM
