rb26dett into sierra 4x4
a standard cossie engine fetechs up to 2k
only reason i asked is the 4x4 gearbox seems the best upgrade and the hardest bit seems to be making it fit the cossie engine,
and as above the rb26 seem to be making really good power standard
can anybody see any obvious problems??
ever since i put the skyline box in mine I wondered if the enigne would fit in,I would consider it if my enigne goes pop,either the bulkhead or radiator would need moving,its a long engine
If you look at the new Fast Ford mag there is an Escort Cosworth with a Skyline engine in. Not a Sierra I know but might give you some pointers as both cars had similar engines in from the factory
Hi interesting thread the escort cosworth in performance ford mag thus month is mine and I had to move the bulkhead back 8" to fit the straight 6. The sierra and escort cosworth engine bay is very similar so with bulk head mods it would be possable but you would have to make sure you get the rear diff the same ratio as the front skyline diff unless you fit skyline rear axel aswell
read the article today, fantastic car you have fella
the escort is rwd though isnt it, i ahavnt read the article yet
but going 4wd when i measured everything up to get the driveshafts straight you wouldnt have to touch the bulkhead but the engine wanted to sit where the slam panel is
truffleshuffle
10-09-2015 09:35 PM
Adam Graham
06-09-2015 06:04 AM
