Focus ST BOOST SOLENOID LOCATION HELP!!
Not sure if this helps but thought id add it anyway, if your looking for the solenoid because your having problems with the boot unlocking randomly while driving and working intermittently its probably because the little rubber handle thing you use to open the boot with normally is full of water and is knackerd. Its a common problem with them and i had the same thing on mine.
JK12
33
26-04-2021 01:09 PM
