Suspension/transmission differences between standard Puma 1.7 and FRP?
As above. Obviously the engine is tweaked, and it has the wider body, but what was done to the suspension and running gear to accommodate the wide track? Presumably it had different lower arms, but what else is different?
Ta!
Ta!
McGarrity Motorsport
Revised Ford Puma B5 Five-speed
Viscous-coupled, limited slip differential
Longer driveshafts
revised bottom arms
Independant MacPherson struts with uprated offset coil springs and dampers, anti-roll bar ( i think it was eibach)
Semi-independent twist beam with strut-type uprated coil spring and damper units, rear spacers (12.5mm i think )
Longer driveshafts
revised bottom arms
lsd started off being a standard feature but changed to being an option, which also slightly lowered the price by the same amount as the option
mike elsome
14-09-2015 04:08 PM
Adam Graham
06-09-2015 06:04 AM
