brake question
brake question
i want bigger brakes for my 2wd saph but i can't afford ap's can you just fit bigger discs and use the standard caliper?
Testing the future
you can use bigger discs with the standard calipers. i'm putting on 330mm discs and spacing the calipers out and apart. due to the different diameter, the pads don't exactly fit the discs though, but i don't see that as a problem.
