audis on high mileage?
±§~Quadzackular~§±
Just been looking about and saw a a6 with 188k miles and the service light on.
Are they a good car for 900 notes? Just a 1.8 t se model. Not drev
Cheers!
Cheers!
yam yammer
Generally good cars that take the miles well. I would say correctly maintained it has plenty of life left. Give it a good test drive though to make sure it's running as it should and that everything works electronically etc.
A lot of people service themselves but don't have VAGcom to turn the lights out. It will have one of three service displays oil, In 1 or In 2. Mine had teh lights on when I got it and that was 65,000 miles ago and is now on 146,000. Can't knock it, best car I've owned bar none.
Only thing to watch for really is the multi link suspension as the ball joints wear and really need to be done as a full set of 8 arms 2 upper and 2 lower on each side with additional drop links and TRE's. Without exception ALL pattern items are total fucking shit and you must replace with OE quality kit which leaves you with either Meyle or Lemforder. Regular oil chnages are a must as well as the engines are prone to sludging which block the pickup strainer and fucks the engine
Spelling Club King!
Drive it. If it drives like a high miler, then walk away. If if drives mint, and feels tight then it's worth considering.
It all depends on what kind of life the car has led. You could get a 200K car that drives better than a 50K car if one has had the shit kicked out of it, and not been looked after properly.
serviced it myself though, £60 for the parts from halfrauds (with trade)
The service lights on Audi's up to 2004 can be reset yourself using odometer button/ignition key, etc. Not sure of the sequence, but it is quite easy.
Not always, I've done 2 or 3 now and on each occasion the various suggested sequences did nothing and it required a reset with VAGcom
Very true about the oil pick up tube from what I read it's to with the steamers using the wrong oil when servicing the cars when they were new and this caused slugging in the sump.
competant bodger
ive known the strainers on these to block with an engine flush as well so dont flush it
as mentioned above the front suspension needs checking too can run into hundreds of pounds replacing the front arms
and as also mentioned they aint the fastest of things, to be frank they feel pretty flat on boost to be fair
Good engines if looked after. dicko on here had an octavia vrs with the 1.8T, done something stupid like 220k miles, and it ran like a swiss watch. it had been very well serviced and looked after though.
Im interested in this as im actually looking at getting one atm myself but was slightly put of by the amount of high millage ones about. Sounds like they will run on for ever though if looked after!
