Pinto with volvo 16v heads?
Can anyone shed any light on these bad boys??
http://www.youtube.com/watch?v=jMsMH...eature=related
http://www.youtube.com/watch?v=I6nDqH06SNg&NR=1
http://www.youtube.com/watch?v=CJBcA...eature=related
Commonly done on the USA LIMA engine, some refer to them as a pinto "engine" as the LIMA,(a 2.3 version very similar to out pinto) engines are often found in the PINTO CAR, the PINTO car was available with a 2L OHC engine that we call the PINTO, hence the confusion.
It's a very effective conversion on the LIMA engine, same as found in MERKUR xr4ti.
nope,it wont.
these bottom end are cheap as chips.
and remember a stroker kit with all bits and bobs are 2500-2800 usd.
can build a 2.7 liter with folvo head for around 4k
Marv understands the Sweedes and other Scandanavians use a big Volvo sohc that the head is removed from and then a 16v head from a smaller motor and the two then fitted to produce a big 16 valve "axle breaker", supposed to be cheap and available and easy to fit into a rwd escort
your scandinavians fit more than just volvo engines to mk1 and 2 escorts though
biggest standard engine ive seen is 2.5 in the penta 16v boat engine,but there are stroker kits available.i think you can swap and change parts fromdifferent engines to increase capacity to about 2.6l. not doubting you,ive just never seen the engine you refer to. turbobricks.com is a good site for volvo engine goodness
they are used in motorsport in the land of Sweeds
ah yeah,i know that way,thought you meant there was a 2.7 engine as standard out there, not using different rods etc.its a very good conversion,rsi also do stroker kits up to 2.8 iirc
What would you rather have an engine designed by Cosworth or something basically botched together?
billett crank with carrillo rods and ross pistons are 1100£. 2,5-2.85 liters can rev 9000 with the 2,5 stroke
head from pyropete is 600£
complete engine ranger 2,5 250£
modification to block 100£
esslinger dry sump kit 1200£
im going too try making one. aim is 600 bhp with a lot of torque.
chowfornow
14
05-01-2019 09:01 PM
