HELP st 170 power problems
Old Jul 14, 2011 | 05:09 PM
ewan's Avatar
ewan
Default HELP st 170 power problems
Hi all in need of some help right diving to and from work today and the car wouldent rev past 3000 rpm it would reatch 3000 rpm then judder vilantley and eventually when i put my foot to the floor the car got all choked up and would die. But if i accelerated a little gradully the revs would go higher then whilst stationery it wouldent rev past 4000 rpm never used to do that then it died and when i tried to start it the engine would just shake and judder sitting below 1000 rpm and would not rev when i accelerated it would die. Please help me Thanks
Old Jul 14, 2011 | 05:48 PM
Farmer Giles's Avatar
Farmer Giles
could be any number of things TBH..
Best bet is to get the codes read off the ECU and see if there are any errors recorded and go from there.
Most likely a faulty or dying sensor IMO..
does the engine light come on at all ? if it does then there will be a code to read off the ECU.
Old Jul 14, 2011 | 05:51 PM
RichieST's Avatar
RichieST
Did you not ask this exact same question a few days ago? Did you investigate what was suggested?
Old Jul 14, 2011 | 06:22 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
some help here
https://passionford.com/forum/techni...-5000-rpm.html
Marino
Sep 12, 2015 11:10 AM
CrOwSoN15
Sep 10, 2015 07:33 PM
BRAM
Sep 8, 2015 07:11 AM
routemaster
Sep 7, 2015 05:27 PM
hopper350
Sep 4, 2015 12:53 AM
